Remote Azure DevOps MCP Server connection with Copilot Studio
Michael Zayed 0 Reputation points
2026-06-17T17:27:42.82+00:00
Hi, just wondering if there is any new information/timeline regarding when the Remote Azure DevOps MCP server can be connected with Agents in Copilot Studio. I have added the link to this message. Thanks
https://learn.microsoft.com/en-us/azure/devops/mcp-server/remote-mcp-server?view=azure-devops&utm_source=chatgpt.com
Microsoft Copilot | Microsoft 365 Copilot | Development
    2026-06-17T17:27:55.06+00:00
    Remote Azure DevOps MCP Server cannot currently be connected to agents in Copilot Studio.
    The documented roadmap states that the remote Azure DevOps MCP Server initially focuses on enabling integration with Azure DevOps from supported clients (Visual Studio Code and Visual Studio) without running a local server. The FAQ explicitly notes that support for other services, including Microsoft 365 Copilot and Copilot Studio, “isn't yet available but will be added soon.” No specific timeline or date is provided in the available documentation.
    For Copilot Studio agent scenarios today, only the general Azure MCP Server (not the Azure DevOps MCP Server) is documented as supported, using templates such as the “Azure MCP Server – ACA with Copilot Studio agent” and the on-behalf-of authentication template.
