browsing history is keep calculating and browsing history don't save.
halloandbye 5 Reputation points
2026-06-15T10:55:44.1966667+00:00
hello, this is happening today, I tried to delete browsing data and saw that is keep staying at calculating even if I wait, also my download and history won't save and reset every time I reset edge. do anyone knows how to fix this? I already tried repairing it but it won't work, anyways thanks for reading it
Microsoft Edge | Favorites, history, and downloads | Windows 11
2026-06-17T03:31:18.15+00:00
I update window security and restarted and now is fixed. I don't think is because of restart because I restarted many times before and it was the same. prob the window security update solve the problem. the thing is I can't guarantee this will not happen again. anyways ill make another post if same issues happens, thanks you and have a good day/night
1 additional answer
  1. Hendrix-V 19,130 Reputation points Microsoft External Staff Moderator
    2026-06-17T02:38:18.06+00:00
    Hi halloandbye,
    Thanks for sharing the details. Since repairing Microsoft Edge did not resolve the issue, the next thing to check is whether the problem is related to the current Edge profile or a policy/settings conflict. Browsing history and download history are stored per Edge profile on the device, so a damaged profile can cause history to stop saving or stay stuck on Calculating.
    To narrow it down further, please try these checking steps:
    1, Test with a new Edge profile
    • Open Edge and go to: edge://settings/profiles
    • Select Add profile.
    • Browse a few websites, close Edge, then reopen it.
    • Check whether the new profile saves history normally.
    2, If the new profile works, recreate the original profile
    • Back up important data first, such as Favorites.
    • Then continue using the new profile, or sign in again and allow your data to sync back.
    3, Check if a policy is clearing history
    • Open: edge://policy
    • Look for policies related to browsing data, history, download history, or clearing data on exit.
    • If the device is managed by an organization, contact the administrator if any policy is applied.
    You can also check the official Microsoft Edge known issues page, although this exact history-saving issue does not appear to be listed in the visible current tracked items.
    Let me know if you need further assistance, feel free to ask me by clicking "Add Comment" or "Add Answer" if you cannot add comment so your response will be visible. Thanks for your effort.
