ClipChamp is NOT working. I need help I have spent days trying to load my clips into ClipChamp
Thomas Roller 0 Reputation points
2026-06-15T10:19:31.76+00:00
I have used ClipChamp for months. It was working fine. I have made dozens of videos with this software.
Right now I can't import clips. All I get is a 0% and a long wait that nothing happens. Even Videos I completed show the 0% and I can't even work with them. I create a new video same problem - I can't import clips.
Also I paid for the upgrade package of ClipChamp. I still don't kow where it is on my system.
Please send me some info who to contact. THANK YOU
Thomas ******@yahoo.com
Microsoft 365 and Office | Clipchamp | Other
  1. Pavle Peković 6,845 Reputation points Volunteer Moderator
    2026-06-15T10:44:26.76+00:00
    Are you using an app or through browser?
    If you are using an app, try in browser: https://app.clipchamp.com/
    If it's working in browser, check if you have enough disk space.
    You can try to repair clipchamp in Settings, Apps, Installed apps. Find Microsoft Clipchamp, click on "...", advanced options and try to repair.
