Redhat Inplace upgrade from Redhat Enterprise Linix 7.9 to 8.10. After successful completion not able to connect from inpremise networl
2026-06-15T00:52:21.8833333+00:00
have done successful in-place upgrade for Redhat Enterprise Linux 7.9 to 8.10. Upgrade completed successfully. After upgrade we are able to login to server through Serial console not able to bring back server to network nor able to SSH from in-premise network server
Azure Virtual Machines
An Azure service that is used to provision Windows and Linux virtual machines.
    2026-06-15T00:52:36.1733333+00:00
    After an in-place Leapp upgrade from RHEL 7.9 to 8.10 on an Azure VM, the OS is up but network/SSH from on-premises is failing. Use Serial Console to verify and repair in this order:
    1. Verify the upgrade completed cleanly
      From Serial Console:
         sudo cat /etc/redhat-release
         uname -r
         sudo dnf repolist
      This confirms the VM is actually on RHEL 8 and using RHEL 8 repositories, as expected after a successful Leapp upgrade.
    2. Check that the network interface is up and has an IP
      Still in Serial Console:
         ip addr
         ip route
         nmcli device status
      Ensure:
      • The primary interface (usually eth0 or ens*) is connected.
      • It has the expected private IP from the Azure VNet.
      • There is a default route via the Azure gateway.
      If the interface is disconnected, bring it up with NetworkManager (RHEL 8 default):
         nmcli connection show
         nmcli connection up <connection-name>
    3. Check local firewall on the VM
      RHEL 8 may have different firewalld defaults than RHEL 7:
         sudo systemctl status firewalld
         sudo firewall-cmd --list-all
      For testing from on-premises, temporarily stop the firewall (only as a diagnostic step):
         sudo systemctl stop firewalld
      Then test SSH from on-premises. If SSH works with firewalld stopped, add a permanent SSH rule instead of leaving it disabled:
         sudo firewall-cmd --permanent --add-service=ssh
         sudo firewall-cmd --reload
         sudo systemctl start firewalld
    4. Verify SSH service on the VM
         sudo systemctl status sshd
         sudo ss -tlnp | grep 22
      Ensure sshd is active and listening on 0.0.0.0:22. If not:
         sudo systemctl enable --now sshd
    5. Check Azure-side networking (from Azure portal)
      Since Serial Console works, the VM is running; the issue is likely network path:
      • Confirm the VM’s NIC and subnet NSGs allow inbound TCP 22 from on-premises (no higher-priority deny rules).
      • Confirm the VM still has the correct private IP and, if used, public IP or VPN/ExpressRoute connectivity from on-prem.
      • If a NAT gateway or custom route tables are used, verify they are unchanged and correctly associated with the subnet.
    6. If Leapp-related issues are suspected
      If the upgrade was from 7.9 directly to 8.10 and there are unexplained issues, one supported mitigation is to upgrade via an intermediate minor version (for example, 8.8) using --target x.y, then move to 8.10 after confirming stability:
         sudo leapp upgrade --target 8.8
      After a successful intermediate upgrade and verification, repeat for 8.10 if required.
    Once network interface, routing, firewall, and SSH service are confirmed healthy on the VM, and NSG/VNet configuration allows inbound SSH from on-premises, connectivity should be restored.
