OneDrive for macOS 13.7.8
Anna N 20 Reputation points
2026-06-14T10:51:36.95+00:00
Dear all,
I need OneDrive for work, but I cannot find the version that supports macOS 13.7.8
Thank you,
Microsoft 365 and Office | OneDrive | For business | MacOS
2026-06-15T00:27:54.5033333+00:00
Hi @Anna N
The latest OneDrive builds distributed via the App Store now require macOS 14.4 or later. On Ventura (13.x), these versions either fail to install or crash on launch because support for Ventura has ended in recent releases.
Community members have shared the following workaround that allows OneDrive to continue functioning on macOS Ventura 13.7.8:
1.Remove current app
Delete OneDrive.app from the Applications folder.
2.Install a stable legacy build
Download and install this package: https://oneclient.sfx.ms/Mac/Installers/26.032.0217.0003/universal/OneDrive.pkg
This information is provided as a convenience to you. These sites are not controlled by Microsoft, and Microsoft cannot make any representations regarding the quality, safety, or suitability of any software or information found there. Please ensure that you fully understand the risks before using any suggestions from the above link.
Do not launch OneDrive yet.
3.Disable updater services
Launch the Terminal app.
In a new terminal, run each of these commands (enter your admin password when asked)
sudo launchctl remove com.microsoft.OneDriveStandaloneUpdater
sudo launchctl remove com.microsoft.OneDriveStandaloneUpdaterDaemon
sudo launchctl remove com.microsoft.OneDriveUpdaterDaemon
4.After that, run these three commands
sudo rm /Library/LaunchAgents/com.microsoft.OneDriveStandaloneUpdater.plist
sudo rm /Library/LaunchDaemons/com.microsoft.OneDriveStandaloneUpdaterDaemon.plist
sudo rm /Library/LaunchDaemons/com.microsoft.OneDriveUpdaterDaemon.plist
5.Restart and run OneDrive
After rebooting, launch OneDrive. It should now operate without updater crashes.
If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment".
1 additional answer
    2026-06-14T10:51:52.9966667+00:00
    For macOS Ventura 13.7.8, OneDrive is still supported, but newer builds may not install or run correctly. The last known working OneDrive version for macOS 13.7.8 (Ventura) is:
    • OneDrive version 26.032.0217.0003 (universal Mac installer)
    To use OneDrive for work or school on macOS 13.7.8:
    1. Uninstall any existing or newer OneDrive versions from Applications (including the Mac App Store version if installed).
    2. Install the standalone OneDrive sync app using the Ventura-compatible installer (version 26.032.0217.0003) as identified in the Microsoft Q&A thread.
    3. After installation, sign in with the work or school account.
    4. Disable auto-update if prompted, so OneDrive does not update to a version that drops support for Ventura.
    Note that only one OneDrive sync app (store or standalone) should be installed at a time on macOS; having both can cause sync issues.
