Troubleshooting website display or functionality issues in Edge on macOS
Why won't apple Passwords work on edge?
AI answer
Apple’s built-in iCloud Keychain passwords don’t integrate directly with Microsoft Edge on macOS. Edge uses its own password manager and policy system, and the available policies only control Edge’s internal password features, not Apple’s system password store.
Relevant Edge password behaviors on macOS:
PasswordManagerEnabled policy.ImportSavedPasswords policy.ImportPasswordsDisabled policy applies only to Android and iOS and controls importing from the built-in mobile password manager.PasswordExportEnabled, which only affects whether passwords saved in Edge can be exported from edge://wallet/passwords.Because Apple’s password system is not a supported import or storage backend for Edge on macOS, Apple Passwords won’t “just work” inside Edge the way they do in Safari. To use passwords in Edge, they must be stored in Edge’s own password manager (for example, by letting Edge save them as sites are visited, or by importing from a supported browser like Chrome or Firefox if those browsers already have the passwords).
Hello, I’m Virginia.
Is there any error message?
Are you using Edge via Windows on the Mac or did you download the Edge browser for Mac OS?
Is there no extension for Edge? With Windows there’s an option to use iCloud for Windows & to integrate the passwords via an extension.
https://support.apple.com/guide/passwords/mchlf7ac261e/mac
Note: This is a non-Microsoft website. The page appears to be providing accurate, safe information. Watch out for ads on the site that may advertise products frequently classified as a PUP (Potentially Unwanted Products).
Please do not download any repair tool which may be offered by this site other than the ones I mention/recommend.
Thoroughly research any product which is mentioned here before you decide to download and install it.
