Build 28000.2333 out RP Cahnnel
CrazyKats 19,415 Reputation points Volunteer Moderator
2026-06-12T17:29:24.2266667+00:00
    2026-06-12T17:29:46.3166667+00:00
    Build 28000.2333 is a Windows 11, version 26H1 Release Preview (RP) build. In Flight Hub, it appears under the RP column for 26H1 builds, while Experimental (26H1) and Beta (26H1) have their own separate build lines.
    For devices enrolled in the Release Preview channel, this build is delivered through Windows Update as part of the 26H1 RP flighting. If a device is instead enrolled in Experimental (26H1) or Beta (26H1), it will receive the corresponding builds listed for those channels (for example, 28020.x builds for Experimental/Beta) rather than RP builds.
    Channel behavior to keep in mind:
    1. Release Preview is a distinct channel focused on more stable, near-final builds for a given Windows version (here, 26H1).
    2. Experimental (26H1) and Beta (26H1) are separate Insider channels with their own build trains (e.g., 28020.x) and are not the same as RP.
    3. Flight Hub is the authoritative place to see which build is in which channel and on what date it was released.
    If a device appears to be receiving a build from a different channel than expected (for example, RP vs. Beta), this can be due to temporary backend issues or channel changes. Similar situations have been reported where devices on Release Preview briefly showed Beta content, and Microsoft confirmed an issue and restored the correct channel behavior afterward.
