Excel - is it possible to exclude data in a result cell based on =IF formula
Lee Jefferies 20 Reputation points
2026-06-12T15:49:45.0333333+00:00
I have the following formula pulling data:
=SUMPRODUCT((Fixtures!$C$2000:$C$2104=$B43)*(Fixtures!$E$2000:$E$2104>Fixtures!$F$2000:$F2104))
Is it possible to add to this formula a way to stop it using the data in the fields if another cell in the origin “Fixtures” tab shows information eg. Yes.
In Fixtures!B2000:B2104 l want to show “Yes” to exclude the data in C,E & F columns from being used. If the B column is blank the data is C,E & F would be used.
Hopefully that makes sense!!
    2026-06-12T15:49:58.55+00:00
    Use an extra condition in the SUMPRODUCT that checks column B and only includes rows where B is blank.
    Adjust the ranges so they all match (2000:2104) and add the B-column test:
    =SUMPRODUCT(
      (Fixtures!$E$2000:$E$2104>Fixtures!$F$2000:$F$2104)*
      (Fixtures!$B$2000:$B$2104="")
    Explanation:
    • (Fixtures!$B$2000:$B$2104="") returns 1 for rows where B is blank and 0 where B contains "Yes" (or anything else).
    • Multiplying this by the other conditions makes SUMPRODUCT ignore rows where B is not blank.
    If instead you want to explicitly exclude only rows with "Yes" and allow other text, use:
    =SUMPRODUCT(
      (Fixtures!$B$2000:$B$2104<>"Yes")
