Technology setback
Siddardha Kushal Bysani 0 Reputation points
2026-06-12T15:35:31.83+00:00
I have a setback that present technology is running fast but the teaching field is in retro model , what the student should to do to improve my present coding skills, generating ai, making apps, and learn latest technology?
    2026-06-12T15:35:58.3366667+00:00
    Technology is moving quickly, but there are structured ways for students to stay current and build strong skills in coding, generative AI, and app development using Microsoft’s education resources.
    1. Build AI and coding foundations
    • Follow the AI for educators learning path to understand AI basics, large language models, generative AI, and prompt engineering. Even though it is designed for educators, the content is equally valuable for motivated students who want a solid foundation in AI concepts and responsible use.
    • Use this path to learn how AI is integrated into tools like Microsoft Copilot, Word, PowerPoint, Microsoft Edge, Minecraft, and more, which are the same tools used in modern workplaces.
    1. Learn to use generative AI and Copilot effectively
    • Explore modules such as Enhance teaching and learning with Microsoft Copilot and Equip and support learners with AI tools from Microsoft (within the AI for educators path). These show how to:
      • Design effective prompts.
      • Analyze and verify AI-generated results.
      • Use Copilot and other AI tools to brainstorm, debug code, summarize documentation, and generate examples.
    • Practice “appropriate reliance”: always verify AI output with trusted sources and use AI as a partner, not a replacement, for thinking.
    1. Use student-focused AI learning resources
    • The AI Fluency Learning Path provides comprehensive coverage of AI basics, generative AI, and responsible AI principles.
    • AI Adventurers offers short videos plus teaching materials that explain how AI works and how it helps solve problems—useful for building intuition about AI systems.
    • The Generative AI Classroom Toolkit gives structured activities and narratives that help learners aged 13–15 (and beyond) understand how to use generative AI safely and responsibly.
    1. Practice information literacy and critical thinking Modern coding and AI work require strong information literacy:
    • Use Information Literacy Fundamentals and Search Progress and Coach to learn how to:
      • Evaluate online tutorials and code samples.
      • Check sources and detect bias or misinformation.
    • Try The Investigators (Minecraft Education) or Reed Smart: AI Detective (Minecraft Education) to practice evaluating sources, spotting AI-generated content, and understanding AI misuse in an engaging way.
    1. Learn app and AI integration through educator-focused courses Even if still a student, it is possible to benefit from educator courses:
    • Empower educators to explore the potential of artificial intelligence shows practical ways AI supports personalized learning and data-driven decisions. The same patterns apply when building apps that use AI to adapt to users.
    • The MSLE Generative AI for Teaching Bootcamp and Microsoft Learn for Educators Generative AI for Teaching Bootcamp outline how to:
      • Use Microsoft Copilot and prompt engineering.
      • Explore upcoming Copilot features and AI agents.
      • Integrate AI tools into real workflows. The concepts (prompting, agents, workflow integration) are directly relevant to app and AI development.
    1. Plan a personal learning path A practical sequence for a student could be:
    2. Complete the AI Fluency Learning Path to understand AI and generative AI fundamentals.
    3. Work through the AI for educators learning path to see concrete uses of Copilot, Edge, Word, PowerPoint, Minecraft, and other tools.
    4. Use the Generative AI Classroom Toolkit and AI Adventurers to deepen understanding of AI behavior and responsible use.
    5. Strengthen information literacy with Information Literacy Fundamentals and Search Progress and Coach so that online coding and AI resources are used safely and effectively.
    6. Apply these skills by building small projects (for example, using Copilot to help design, document, and test code) and iterating frequently.
    These resources help close the gap between “retro” teaching models and fast-moving technology by giving structured, up-to-date learning paths that students can follow independently or alongside formal classes.
