Cast Worked and Failed
Liam Dettman 5 Reputation points
2026-06-12T07:18:38.67+00:00
So, I Was Always Wanting to Cast (Windows + K) I Could Cast to the T.V, But Now I Can't Cast to It.
Windows for home | Windows 10 | PC projection
  1. Vikki-T 10,195 Reputation points Microsoft External Staff Moderator
    2026-06-12T12:40:53.1133333+00:00
    Hi Liam Dettman,
    Thanks for sharing the details. I understand how frustrating it can be when casting with Windows + K used to work normally, but now your PC can no longer connect to the TV.
    To better understand the situation, could you please share a few more details?
    • When you press Windows + K, does your TV still appear in the list, or does it not show up at all?
    • Do you see any error message when the connection fails?
    • What is the brand and model of the TV?
    • Did this start after a Windows update, driver update, TV firmware update, or router/Wi-Fi change?
    • Are other devices still able to cast to the same TV?
    In the meantime, please try these steps:
    • Make sure Wi-Fi is turned on: on your Windows 10 PC Wireless display/casting depends on Wi-Fi/Miracast, so please confirm Wi-Fi is enabled before trying to cast again.
    • Check the TV’s casting mode: On the TV, make sure Screen Mirroring, Miracast, Wireless Display, or a similar casting mode is enabled. Some TVs need to be manually placed into this mode before Windows can detect them.
    • Restart both devices: Restart the Windows PC and fully power cycle the TV. If possible, unplug the TV from power for about 30 seconds, then turn it back on and try Windows + K again.
    • Remove the old TV connection and pair it again: On the PC, go to Settings > Devices > Bluetooth & other devices. Under Wireless displays & docks, select the TV or wireless display adapter, then choose Remove device. After that, press Windows + K and try connecting again.
    • Update display and Wi-Fi drivers: Open Windows Update and install any available updates, including optional driver updates if shown. You may also want to check the PC manufacturer’s support site for the latest Wi-Fi and graphics drivers.
    • Update the TV or wireless display adapter firmware: If your TV or Miracast adapter has a firmware update option, please install any available update and test again.
    I hope these checks help restore the casting connection. While my initial response may not fully resolve the issue, I truly appreciate your cooperation as we work together toward identifying the most effective solution. Thank you so much for your understanding.
  2. Liam Dettman 5 Reputation points
    2026-06-19T23:23:03.03+00:00
    I don't have "Devices" on settings.
  3. Liam Dettman 5 Reputation points
    2026-07-04T21:43:51.37+00:00
    I meant i had "Devices" on settings i just don't remember where it was.
