Using named data range for box and whisker plot?
Andy Entrekin 20 Reputation points
2026-06-11T19:51:35.8033333+00:00
I've got a Box and Whisker plot of a single data series, but the series expands over time. So far, I've been unable to find a clean way to keep the plot updated. I thought I could use Name Manager to define a named range using the OFFSET function, so I set that up. The named range works exactly as I want. But I can't use it in the Select Data dialog for the chart. More accurately, I can enter the name but Excel converts it to the current evaluated range when I apply it. I enter "=Data!PayDelay" in the form, but when I click OK I can see it get converted to "=Data!$E$3:$E$199" (the current range). If I add a value in E200, it is not reflected in the plot unless I repeat this exercise (in which case it's just as easy to update the cell reference and not bother with the named range). This is Excel on my Windows machine, not the web version, in case that matters. What am I missing?
Hendrix-C 20,015 Reputation points Microsoft External Staff Moderator
2026-06-11T20:47:44.64+00:00
Hi @Andy Entrekin,
Based on your sharing, if the named range are correctly defined with OFFSET and then added to the data ranges in Select Data, normally Excel should keep the define named without converting it to current range. I have tried to reproduce the problem you are experiencing, but I couldn't gather more details or insights into the problem causing it.
However, I suggest you can consider trying using Excel Table for your case. It has the same dynamic approach with OFFSET define names that when you add a new value directly below the table, Excel expands the table automatically and the chart referencing to the table also updates automatically. You just need to select the data range (e.g A1:E200) then go to Insert > Table (or use shortcut Ctrl + T) > check the Headers box if your data has headers > OK. Then normally create the Box & Whisker chart with that data table.
You can give it a try and see if it meets your needs. If not, don't hesitate to reach out again and we can work together to find the best approach for your concern.
If you have any questions or need any further clarification, please leave a comment here and I will be happy to continue to help you.
Thank you for your patience and understanding. I'm looking forward to your reply.
If the answer is helpful, please click "Accept Answer" and kindly upvote it.
Note: Please follow the steps in our documentation to enable e-mail notifications if you want to receive the related email notification for this thread.
0 additional answers
