Questions always Deleted
Noroelle 20 Reputation points
2026-06-11T16:04:58.82+00:00
I'm trying to Post a Question for Troubles in Microsoft Home with Windows 11.
i have some Links with Minidumps from Google Drive there and Long Text for everything i tried and what errors Windows shows me when it crashs.
I don't know why it is always directly deleted and what can i do so that the question isn't deleted or that some Moderator can bringt that question Online?
Sadly I Don't remember the last title. Should i repost it with a new name?
Thanks.
Community Center | Discuss the Q&A site | Site bug or problem
JuliaMarvin 22,910 Reputation points Volunteer Moderator
2026-06-11T16:58:00.5+00:00
I've undeleted your thread: https://learn.microsoft.com/de-de/answers/questions/5917341/windows-11-home-pc-crasht-immer-wieder
The automatic spam filter is sometimes causing troubles ;)
1 additional answer
    2026-06-11T16:05:12.36+00:00
    Questions on Microsoft Q&A can be deleted automatically by the spam filter or manually by moderators if they appear to violate the Q&A code of conduct or site guidelines.
    From similar reported cases, detailed technical questions (including long text and external links such as to minidumps) are sometimes incorrectly flagged and auto-deleted by the spam system as false positives. Moderators can then restore them.
    To proceed:
    1. Sign in with the Microsoft Learn profile when posting the question.
    2. Post the question again in the appropriate Q&A product/tag area.
    3. If it is auto-deleted, create a short meta-question in the Community Center → Site bug or problem area (like this one) explaining that the original question is being auto-deleted by spam. Include the title of the deleted question so moderators can locate it.
    4. A moderator can then:
      • Restore the question if it was deleted by mistake (as shown in the examples where questions were “automatically deleted by spam filter by mistake” and then restored), or
      • Edit or delete it if it actually violates the Q&A code of conduct.
    If the question is restored and still needs edits (for example, to remove content that violates guidelines), moderators can edit it or ask for clarification instead of deleting it.
    If the issue is related to AI-generated content and it was removed for that reason, there is an appeals process for deletions or suspensions due to AI usage on Microsoft Q&A described in the AI usage policy.
