Matching index to populate value
Mel S 20 Reputation points
2026-06-11T13:59:02.42+00:00
I am having issues on my formula for Column A. I want the column to return yes if there is a value in the intersect of I2:H5, return no if there is no values (cell blank), and return N/A if the match doesn't exist.
Cell A5 is returning yes, but the intersect of those values (cell K2) is blank and I want this to return no. This particular issue is then raising concerns I have for my formula for Column B, where if Column A is yes, pull the actual intersect value from I2:H5
2026-06-11T14:51:49.0833333+00:00
Hi @Mel S,
Thanks again for the clear explanation. It really helps to understand what you’re trying to achieve.
From what I can see, there might be a small misalignment in the ranges used for your lookup. It looks like your INDEX range starts from row 2 (I2:K5), while the row MATCH is referencing a range that starts from row 1 (H1:H5). This difference can sometimes cause the matched row position to shift slightly.
You could try adjusting the row MATCH range to H2:H5 so that it lines up more closely with the INDEX range. This may help the formula return the expected result when the intersecting cell is empty.
For reference, here’s a version of the formula you might want to test for Column A:
=IF(
OR($N2="",$M2=""),
"N/A",
IFERROR(
IF(
INDEX($I$2:$K$5,MATCH($N2,$H$2:$H$5,0),MATCH($M2,$I$1:$K$1,0))="",
"NO",
"YES"
"N/A"
And for Column B, if you’d like to return the intersect value only when Column A is "YES", you might try:
=IF($A2="YES",INDEX($I$2:$K$5,MATCH($N2,$H$2:$H$5,0),MATCH($M2,$I$1:$K$1,0)),"")
User's image Of course, this is just a suggestion based on what I’m seeing, but hopefully it points you in the right direction. Please feel free to give it a try and let me know how it goes.
0 additional answers
