Learning path issue
Innokentii Li 0 Reputation points
2026-06-11T12:51:22.7233333+00:00
Hi, I recently finished GitHub Copilot Fundamentals Part 2 of 2 learning path and completed all module assignments.
But for some reason, there is no "All module assignments passed" badge on it.Screenshot 2026-06-09 202714
    2026-06-11T12:51:43.0333333+00:00
    The behavior described is consistent with how Microsoft Learn currently handles course and learning path achievements:
    • Microsoft Learn awards badges for individual modules and trophies for completing learning paths.
    • There is no separate certificate for completing a course or learning path, and not every learning path exposes an “All module assignments passed” indicator in the same way.
    Because of this, the absence of the green “All module assignments passed” label on the GitHub Copilot Fundamentals Part 2 of 2 trophy does not affect the actual completion status of the learning path. The important indicator is that the learning path trophy appears under Achievements → Learning Paths with a completion date, which confirms successful completion.
    If the learning path trophy is present and shows as completed, no further action is required. For issues with exam-based certifications (for example, GH‑300 or other proctored exams), those are handled separately under the Certifications area of the Microsoft Learn profile and may take 24–48 hours to appear.
