How to use SUM and SUMPRODUCT across a range of sheets
Lamtek 0 Reputation points
2026-06-11T12:49:53.16+00:00
I have a range of work sheets with product codes in the cells A13 - A45 and Colours of products in the cells B12-F12
I have created a summary sheet for these work sheets that counts the values in all cells where the product and cplour match the values entered on the summary sheet.
I would like to summaries multiple job sheets on to the summary sheet by using the range of sheets rather than having a formula for each sheet and adding them together.
The basic formula is
=SUM(SUMPRODUCT(SHEET1!$B$13:$F$45*(SHEET1!$B$12:$F$12=B$12)*(SHEET1!$A$13:$A$45=$A13)))
At the moment the only solution I have found is to add the same formula together for each sheet I want to summaries i.e.
=SUM(SUMPRODUCT(SHEET1!$B$13:$F$45*(SHEET1!$B$12:$F$12=B$12)(SHEET1!$A$13:$A$45=$A13)))+=SUM(SUMPRODUCT(SHEET2!$B$13:$F$45(SHEET2!$B$12:$F$12=B$12)*(SHEET2!$A$13:$A$45=$A13)))
I know I should be able to simply use the range SHEET1:SHEET25 but I can't find a solution that works.
Can someone help please
Microsoft 365 and Office | Excel | Other | Windows
    2026-06-11T12:50:07.43+00:00
    3-D sheet ranges such as Sheet1:Sheet25 cannot be used inside SUMPRODUCT, because 3‑D references are only supported by a limited set of functions (for example SUM, AVERAGE, MIN, MAX, etc.) and are not valid in array formulas like SUMPRODUCT.
    From the documentation:
    • 3‑D references (e.g. =SUM(Sheet2:Sheet13!B5)) can be used with functions such as SUM, AVERAGE, COUNT, MAX, MIN, PRODUCT, STDEV.P, STDEV.S, VAR.P, VAR.S, etc.
    • 3‑D references cannot be used in array formulas.
    SUMPRODUCT is an array-based function, so a construct like:
    =SUMPRODUCT(Sheet1:Sheet25!$B$13:$F$45*...)
    is not supported.
    Because of this limitation, the approach of repeating SUMPRODUCT for each sheet and summing the results is the supported method when staying purely in worksheet formulas, for example:
    =SUM(
      SUMPRODUCT(Sheet1!$B$13:$F$45*(Sheet1!$B$12:$F$12=B$12)*(Sheet1!$A$13:$A$45=$A13)),
      SUMPRODUCT(Sheet2!$B$13:$F$45*(Sheet2!$B$12:$F$12=B$12)*(Sheet2!$A$13:$A$45=$A13)),
    There is no supported way, using only standard worksheet functions, to combine SUMPRODUCT with a Sheet1:Sheet25 3‑D sheet range into a single compact formula.
