IF, AND & ISBALNK
Chaturvedi, Santosh 430 Reputation points
2026-06-11T12:31:02.0233333+00:00
Hello --> Greetings !!
I have one question.. See fig. below..
If cell D3766 is blank ("-") then H3766 shall be also blanl ("-")
This shall be combined with IF, AND and formula shown below.
=IF(AND(D3765<$E$3210,D3765>=$E$3207),4,7)
Liora D 18,930 Reputation points Microsoft External Staff Moderator
2026-06-11T13:17:44.8233333+00:00
Dear @Chaturvedi, Santosh,
I hope you’re having a good day.
Thank you for reaching out and for your clear explanation.
From what I can see in your example, your current formula already works for the range condition, and now you’d like to extend it so that when the value in column D is “blank” (shown as “-”), column H should also return “-” instead of calculating.
Based on your description, the key point to clarify is how Excel treats that “-” value.
Even though it looks like a blank cell, in most cases Excel does not consider “-” as empty. It is usually treated as either: a text value ("-"), or a formatted display (for example when the actual value is 0)
Because of that, a function like ISBLANK() will not behave as expected here.
To handle your requirement correctly, you need to check the value in column D before applying your existing IF/AND logic.
A simple way to do that is:
=IF(D3766="-","-",IF(AND(D3766<$E$3210,D3766>=$E$3207),4,7))
How this works
  • If D3766 contains "-" > return "-" directly
  • Otherwise > apply your original formula IF(AND(...), 4, 7)
If you want to make it more robust. In case some rows might be truly empty (not just "-"), you can extend it like this:
=IF(OR(D3766="",D3766="-"),"-",IF(AND(D3766<$E$3210,D3766>=$E$3207),4,7))
Note: The behavior of your formula depends on what the cell really contains, not just what it displays. So if needed, you can double-check by clicking the cell, looking at the formula bar to see whether it is: empty; "-", or a number formatted to show as "-"
I hope this helps you implement the logic you need. Please feel free to reply below if you have any update or further concern.
Thank you and wishing you success with your worksheet!
Warm regards,
1 additional answer
  1. Chaturvedi, Santosh 430 Reputation points
    2026-06-11T13:25:56.53+00:00
    I have applied this formual and is working perfect !!
