Disable Sidebar on Edge
Vicky Davies 0 Reputation points
2026-06-11T09:17:27.2833333+00:00
How do you disable the whole sidebar in version 149.0.4022.52?
I am being told by our internal IT department: "As per Microsoft, you can no longer disable the sidebar in Microsoft Edge 149.0.4022.52 — because Microsoft removed the ability to turn it off in this version."
This change is having an impact on how I work as takes valuable screen space. Why can this setting not be made optional for users preference!
Microsoft Edge | Tabs, address bar, and search | Previous Windows versions
  1. SD - IA 178.9K Reputation points Independent Advisor
    2026-06-11T09:57:08.3133333+00:00
    The IT department probably misunderstood. There is no option to disable the sidebar because the sidebar will be completely removed in future versions. It is already gone from both of my machines.
    In the meantime, try this if you have admin access on the PC.
    In the Windows search,
    Type cmd, right-click it, and choose Run as Administrator.
    Run this command:
    reg add "HKLM\SOFTWARE\Policies\Microsoft\Edge" /v HubsSidebarEnabled /t REG_DWORD /d 0 /f
    I’m eager to hear back and work together to find a solution.
  2. Lucus-V 12,535 Reputation points Microsoft External Staff Moderator
    2026-06-15T20:34:55.2133333+00:00
    Hi Vicky Davies,
    The sidebar itself and Copilot are not being removed. What is being retired is the “sidebar app list” (also called the App Tower) that showed pinned mini‑apps.
    On most recent Edge version 149.0.4022.69, Sidebar still can be toggled by navigating to Settings > Appearance > Sidebar.
    If you have further questions, please feel free to let me know.
