how can i prevent window alarm from sounding
anton lazar 20 Reputation points
2026-06-10T14:11:41.2633333+00:00
i use window alarm so that i can set my sleep time but i dont want it to sound just the widget is enough but there's no option for no sound
Windows for home | Windows 11 | Apps
Lester Bernard Reyes 85,500 Reputation points Independent Advisor
2026-06-10T14:49:10.8466667+00:00
Hi, I'm Bernard. I'm happy to help!
To remove the audio, open the clock app > click Settings
Turn off "End of session sound" and "End of break sound"
Note: This is a public forum. I may respond shortly, but I apologize in advance for any delays. I am simply a fellow user trying to provide helpful insights and information.
1 additional answer
    2026-06-10T14:11:51.2666667+00:00
    Windows Clock alarms always use a sound, but the alarm can be effectively silenced by muting or visually replacing the sound with screen flashes and visual notifications.
    Use one of these approaches:
    1. Turn system volume to 0 when the alarm is due
      • Select the Sound icon on the taskbar.
      • Drag the Volume slider to the lowest level (0). This mutes all sounds, including the alarm, while still allowing the alarm toast/notification to appear.
    2. Use visual alternatives to sound
      • Select Start > Settings > Accessibility > Audio.
      • Under Flash my screen during audio notifications, choose how the screen should flash when an audio notification (including alarms) occurs. This gives a visual cue instead of relying on sound.
    3. Make notifications easier to see
      • Select Start > Settings > Ease of Access > Display.
      • Under Show notifications for, increase the time so alarm notifications stay visible longer.
    With volume muted and visual alerts enabled, the alarm will still trigger and show on screen, but no sound will play.
