One Note alphabetical order
Peter Pribylinec 0 Reputation points
2026-06-10T11:21:00.3633333+00:00
The alphabetical sorting of section names and pages within sections doesn't seem to be working for me… any idea how to set it up?
Microsoft 365 and Office | OneNote | For home | MacOS
  1. Marcin Policht 107K Reputation points MVP Volunteer Moderator
    2026-06-10T11:42:23.6833333+00:00
    AFAIK, OneNote allows you to sort pages automatically, but it does not have a built-in button to automatically sort sections. To sort pages, check the top of your page list on the right or left sidebar. Click the Sort icon (it looks like a set of arrows or a small list). Select Alphabetical. Unfortunately sort sections would be done manually. Click and hold the section tab, then drag and drop it into the order you want. As a workaround, you might consider adding numbers or letters to the front of their section names (like "A_Notes" or "01_Projects") .
    If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
    hth
    Marcin
