Microsoft for Startups / Founders Hub login loop and LinkedIn verification error
Roman Dziavgo 0 Reputation points
2026-06-09T22:43:10.5666667+00:00
I am unable to access Microsoft for Startups / Founders Hub and activate the $1,000 starter Azure credits.
According to the Microsoft for Startups documentation, after recent program changes, users who joined after May 29, 2026 should use the Azure Portal as the primary experience, and they should be able to access $1,000 starter credits while the application is under review.
However, I am blocked by a login / verification issue:
  1. When I click "Sign in with your Microsoft account", authentication appears to complete, but I am redirected back to:
portal.startups.microsoft.com/login
I never reach the Founders Hub dashboard.
When I try to sign in or verify through LinkedIn, I get:
"No user found. Please sign up or try a different LinkedIn account."
Previously, after the LinkedIn callback, I also received this error:
{"error":{"code":"BadRequest","message":"BadRequest (Conflict)"}}
This looks like a Microsoft for Startups / Founders Hub account provisioning, migration, or identity linking issue, not an Azure quota issue.
I have already tried using different Microsoft accounts, but the portal still redirects me back to the login page.
How can I resolve this login loop and link my Microsoft account / LinkedIn verification correctly so I can access the Founders Hub dashboard and activate the starter Azure credits?I am unable to access Microsoft for Startups / Founders Hub and activate the $1,000 starter Azure credits.
Azure | Azure Startups
Startups: Companies that are in their initial stages of business and typically developing a business model and seeking financing.
    2026-06-09T22:43:35.4766667+00:00
    This issue cannot be fixed from the client side and requires Microsoft for Startups Program Support to investigate and correct the account provisioning / identity linkage for the startup profile.
    Because the sign-in completes but returns to portal.startups.microsoft.com/login, and LinkedIn verification reports "No user found" or BadRequest (Conflict), the startup account is not being created or linked correctly. In this situation, the supported path is to open a Microsoft for Startups support ticket so the program team can:
    • Validate which Microsoft account (MSA) is associated with the startup application
    • Check for conflicting or partial Founders Hub / Microsoft for Startups records
    • Correct the entitlement and identity linkage so the account can access the program experience (Azure Portal or Startups Portal, depending on join date)
    Follow these steps:
    1. Go to the Microsoft for Startups Portal support entry point: https://portal.startups.microsoft.com/login
    2. If sign-in succeeds but loops, use a different browser or an InPrivate/Incognito window to ensure cookies are clean, then sign in again.
    3. Once signed in successfully in any way, select the "?" icon in the top-right corner.
    4. Select "Submit a Support Ticket".
    5. In the ticket, include:
      • The exact Microsoft account(s) being used to sign in
      • The LinkedIn account used for verification
      • The error messages observed, including "No user found. Please sign up or try a different LinkedIn account." and {"error":{"code":"BadRequest","message":"BadRequest (Conflict)"}}
      • A description that the portal redirects back to /login instead of loading the dashboard
    6. Attach screenshots of the login loop and LinkedIn error to help the support team identify the provisioning conflict.
    If unsure which MSA was used to activate or attempt to activate credits, note that in the ticket; Microsoft for Startups Support can help identify the correct account and, if needed, process an entitlement transfer so the right account owns the startup credits.
    Once the program support team resolves the provisioning and entitlement linkage, the startup should be able to:
    • Access the Microsoft for Startups experience (Azure Portal for post–May 29, 2026 joins, or Startups Portal for earlier joins)
    • Activate and manage the $1,000 starter credits and subsequent Startup credits from the appropriate portal experience
