Remote Desktop Gateway deployment dropping connections with HTTP Error 503 Service Unavailable
Midi Ninasch 25 Reputation points
2026-06-09T14:57:39.68+00:00
Environment: External Remote Desktop Gateway for work-from-home access
Change implemented: Monthly security patches installed on gateway host
Impact: Users unable to connect to office desktops remotely
Error displayed: "The remote computer could not be contacted. HTTP Error 503"
Service status: RD Gateway service is running and active
Issue: Remote connections fail immediately despite gateway service availability.
Windows for business | Windows 365 Enterprise
Harry Phan 33,315 Reputation points Independent Advisor
2026-06-09T15:57:05.23+00:00
Hi Midi,
That error means the gateway web service itself isn’t responding, even though the main RD Gateway program looks like it’s running. After the security patch, the part of Windows that delivers the gateway through IIS likely stopped working. Usually this happens if the SSL certificate on port 443 isn’t loading correctly or if the “RDGateway” application pool in IIS crashed. The fix is to open IIS Manager, check that the RDGateway pool is started, and confirm the certificate binding is still valid. If the pool keeps stopping, it’s tied to the latest update and may need either a rollback of that patch or waiting for Microsoft’s hotfix. In short, the gateway service is up, but the web layer it depends on is broken.
Hope it helps.
Harry.
0 additional answers
