Need to add Claude Add in
Joel Chavez 0 Reputation points
2026-06-09T02:19:34.28+00:00
I need to add Claude add-in to excel, word & powerpoint. I use office 365 for mac
Microsoft 365 and Office | Excel | For home | MacOS
    2026-06-09T02:19:42.92+00:00
    To add the Claude add-in in Excel, Word, and PowerPoint on Microsoft 365 for Mac, use the Office Add-ins experience in each app.
    1. Open Excel, Word, or PowerPoint on the Mac.
    2. Go to the Insert tab on the ribbon.
    3. In the Add-ins group, select Get Add-ins (or Store in some versions).
    4. In the Office Add-ins dialog, use Search to look for Claude by Anthropic (for Excel, Word, or PowerPoint as needed).
    5. Select the Claude add-in in the results, then choose Add to install it.
    6. After installation, start the add-in from:
      • Insert > My Add-ins, or
      • Home > Add-ins > More Add-ins, then My Add-ins, and select Claude.
    Repeat these steps in each application (Excel, Word, and PowerPoint) to make Claude available everywhere.
    If Claude does not appear in search, the organization or subscription may be limiting which Store add-ins are available, or the add-in may not be offered for that tenant.
