A family of Microsoft presentation graphics products that offer tools for creating presentations and adding graphic effects like multimedia objects and special effects with text.
To both keep the audio with the presentation and have it play across slides on macOS, use two separate steps: (1) insert and configure the audio correctly in PowerPoint, and (2) save/export the presentation in a way that preserves the embedded media.
- Insert and configure audio on macOS
- In Normal view, select the first slide where the audio should start.
- On the ribbon, select Insert > Audio.
- Choose Audio from File and select the audio file from Downloads (or wherever it is stored), then select Insert.
- With the audio icon selected on the slide, go to the Playback tab.
- To have the audio play automatically when the slide appears, set Start > Automatically.
- To have the audio continue beyond the first slide:
- On the Playback tab, select Play across Slides.
- If the audio should loop for the whole show, also select Loop Until Stopped.
This ensures the audio does not stop when advancing to the next slide.
- Save the presentation with embedded audio
When the audio is inserted from file as above, it is embedded in the PowerPoint file. To keep the audio with the presentation:
- Use File > Save (or Save As) and keep it as a standard PowerPoint file (e.g.,
.pptx). This keeps the embedded audio. - When sharing, send the
.pptxfile itself. Recipients must use a version of PowerPoint that supports the media format (see supported formats below).
- Save the audio itself out of PowerPoint (if needed)
If the goal is to extract the audio file that was embedded in the presentation (for reuse elsewhere):
- Right-click (Control-click) the audio icon on the slide.
- Select Save Media as.
- Choose a folder and file name, then select Save.
Notes for macOS:
- Saving embedded media as a separate file is available only for Microsoft 365 subscribers on macOS, beginning with version 16.24.
- If Save Media as does not appear, the PowerPoint version does not support extracting media.
- Check audio format compatibility
If the audio disappears or does not play after saving or sharing, verify that the audio format is supported on the target device. For Office for iOS and Android, supported audio formats include:
.mp3 -
.m4a/.mp4 -
.aiff,.au(iOS) -
.wav,.mid,.midi(Android)
If needed, convert the audio to one of these formats and reinsert it using Insert > Audio > Audio from File.
- Add or delete audio in your PowerPoint presentation
- Add media to a slide in PowerPoint
- Video and audio file formats supported in PowerPoint
- Save embedded media from a presentation (audio or video)
- Trim a video, music clip, or sound clip in PowerPoint
- Are you having video or audio playback issues?
- Play music across multiple slides in your slide show in PowerPoint
- PowerPoint help
