Fax and Scan Nowhere to be found
Kurt L 20 Reputation points
2026-06-08T20:56:29.54+00:00
I don't have Windows Fax and Scan on pc and cannot find it through system, optional features. How can I install either Fax and Scan or simply a Scan program?
Windows for home | Windows 11 | Apps
John DeV 170.1K Reputation points Independent Advisor
2026-06-08T21:39:18.4933333+00:00
Hi, good day!
Let's try to install Windows Fax and Scan using Command Prompt
Press Start then search Command Prompt
Right click it then select Run as administrator
Copy and paste the command below then press Enter
dism /Online /Add-Capability /CapabilityName:Print.Fax.Scan~~~~0.0.1.0
I look forward to receiving your update and I'm willing to collaborate with you till we resolve the issue. Do keep me informed by clicking "Add comment" below.
1 additional answer
    2026-06-08T20:56:40.03+00:00
    On Windows 11, Windows Fax and Scan is installed as an optional feature.
    To install Windows Fax and Scan:
    1. Open SettingsSystemOptional features.
    2. Select View features.
    3. In the search box, type fax.
    4. Select Windows Fax and Scan from the list.
    5. Click Next, then Install.
    If only a scan program is needed (no fax), use the built-in Windows Scan app:
    1. Make sure the scanner is installed and turned on.
    2. Right-click the Start menu and select Search.
    3. Type Windows Scan.
      • If it appears under Apps, select it and use it to scan.
      • If it does not appear, install it from Microsoft Store using this link: Windows Scan.
    4. Place the document or picture in the scanner.
    5. In the Scan app:
      • Choose the correct Scanner and Source (Flatbed/Feeder/Auto-configured).
      • Choose a File type (JPEG, PNG, TIFF, Bitmap).
      • Optionally set Save file to for the folder.
    6. Select Scan to create the file.
    Scans are saved in the chosen folder, or by default in Pictures/Scans in the user folder.
