Need region access for Azure for Students subscription - AI Skills Fest 2026 Lab
Saket Shrivastava 0 Reputation points
2026-06-08T13:08:54.19+00:00
Hello Microsoft Team,
I am currently participating in Microsoft AI Skills Fest 2026 and working
on the following lab:
Lab Name: "Create your first AI agent" (Unit 5/6)
Lab URL: https://microsoftlearning.github.io/mslearn-agent-quickstart/Instructions/Labs/01-get-started-in-foundry.html
I am stuck at the very first step of creating a project in Azure AI Foundry
to deploy the gpt-4.1-mini model.
Error I am getting:
"InvalidTemplateDeployment - Resource 'proj-default-resource' was disallowed
by Azure: This policy maintains a set of best available regions where your
subscription can deploy resources. The objective of this policy is to ensure
that your subscription has full access to Azure services with optimal
performance. Should you need additional or different regions, contact support."
Details:
  • Subscription type: Azure for Students
  • Regions tried: East US 2, Sweden Central, Southeast Asia
  • All regions are blocked by the subscription policy
  • Australia East shows "Insufficient quota"
I have been trying to resolve this for a long time but nothing is working
because of the subscription-level policy restriction. I am a student from
India participating in this event to learn and build AI skills.
Could you please either:
  1. Whitelist my Azure for Students subscription to allow resource creation in East US 2 or Sweden Central, OR
  2. Provide any alternative way to complete this lab
I really want to complete this Skills Fest lab and earn the achievement.
Thank you so much for your help.
Student name: Saket
Microsoft Learn profile: [paste your profile link here]
Subscription ID: [paste your subscription ID from portal.azure.com]
    2026-06-08T13:09:22.9033333+00:00
    The subscription is blocked from deploying to the regions required by the lab due to a region access policy and quota constraints. This is enforced at the subscription level and cannot be bypassed from the portal or by changing regions within the same policy scope.
    To proceed, use one of the supported escalation paths for region access and quota issues:
    1. Try an alternative region that is allowed
      • The error message indicates a policy that restricts deployments to a specific set of “best available regions.”
      • In the Azure portal, when creating the Azure AI Foundry project, check which regions are actually available in the region dropdown (if any) and select one of those.
      • If no region is available for the project resource type under this subscription, continue with the support path below.
    2. Open a support request to remediate region access policy
      • This policy is the same class of restriction described for region access policies in Azure.
      • Create a support request to ask for remediation of the region access policy for the subscription:
        1. Sign in to the Azure portal using the Azure for Students subscription.
        2. Use the “New support request” experience as described in the region access remediation guidance.
        3. In How can we help you?, enter a description such as “region access” or “Unable to access Azure regions”.
        4. For Issue Type, select Service and subscription limits (quotas).
        5. Select the Azure for Students subscription.
        6. For Quota type, select the option that matches the “Unable to access <region> region” pattern if available, or the closest equivalent.
        7. In the description, explain that this is for Microsoft AI Skills Fest 2026, that the lab requires Azure AI Foundry and gpt-4.1-mini, and that all required regions are blocked by policy.
      • This follows the documented pattern for submitting a remediation request when a subscription is blocked from specific regions.
    3. If the region itself is access-restricted (reserved access)
      • Some regions are access restricted and require an explicit access request.
      • If support confirms that the target region (for example, East US 2 or Sweden Central) is a reserved access region for this subscription, follow the reserved access region request process:
        1. In Issue Type, select Service and subscription Limit (quotas).
        2. Select the Azure for Students subscription.
        3. For Quota type, select Other Requests.
        4. In the description, request access for the specific region needed for Azure AI Foundry, and include that this is for training/education (AI Skills Fest 2026) and that you need to deploy Azure AI resources (compute, storage, etc.) there.
    4. If quota is insufficient in an allowed region
      • For regions where the error is “Insufficient quota” (for example, Australia East), request a quota increase:
        1. In a support request, choose Service and subscription limits (quotas).
        3. Choose the quota type that corresponds to the Azure AI / compute resources being deployed.
        4. Request a small increase sufficient for the lab resources.
    5. If support cannot change region access for Azure for Students
      • Some student offers have fixed region policies that cannot be changed.
      • If support confirms that region access cannot be modified for the Azure for Students subscription, the only compliant alternatives are:
        • Use a different subscription that has access to the required regions (for example, a Pay-As-You-Go or other eligible subscription) and repeat the lab there.
        • If no such subscription is available, the lab cannot be completed exactly as written under the current subscription policy; in that case, share the support response with the event organizers so they can advise on alternative credit/subscription options for AI Skills Fest participants.
    These steps align with the documented processes for resolving region access policy blocks and quota issues; the actual whitelisting or policy change can only be performed by Microsoft support and may be subject to the constraints of the Azure for Students offer.
