SC 500 ENU Certificate not received
Vikas Ahuja 60 Reputation points
2026-06-08T10:04:54+00:00
I have recently given Microsoft SC 500 ENU certificate however I have not received my certificate over mail or it's not even showing in learning platform also, kindly help.
Julian Sharp 43,851 Reputation points
2026-06-08T10:23:20.2733333+00:00
The exam is in beta. You are informed of this on the exam page.
You are informed before the exam starts that you will not get the results until after the exam exits the beta period. You are also informed after the exam that you will get your results two weeks after the exam goes live. You will not see anything on Microsoft Learn until that time.
https://learn.microsoft.com/en-us/credentials/support/about-beta-exams#beta-exam-scoring-and-results
"When you complete a beta exam, you won’t receive a score immediately because the scoring model for the exam is not yet finalized. If you’ve taken a beta exam, you’ll receive your score about 10 days after the exam becomes available worldwide or “goes live” -- approximately 10-12 weeks after the beta period begins. This time reflects a comprehensive process including statistically analyzing results and data, evaluating the performance of each question and reading and evaluating all comments provided during the beta exam. As a result, you may not receive a score for 14 weeks depending on when in the beta process you took the exam. Please note that the beta exam process and the time it takes to receive your results may vary."
AI answer
2026-06-08T10:05:20.0666667+00:00
SC-500 exam and certification delivery issues are handled through the Microsoft credentials and certification support channels, not through the general Microsoft 365 forums.
To resolve a missing certificate:
  1. Check the Certification Dashboard
    • Go to your Certification Dashboard (from the Learn profile) and verify whether the SC-500 certification or exam result appears under the Certifications tab.
    • If the certification requires multiple exams, the certificate is only issued after all required exams are passed.
  2. If the certificate still does not appear
    • Open a support request with the Microsoft Credentials Support team, who can check your exam history and certification status and reissue or correct missing certificates.
    • Use the credentials support entry point described in the context (for example, the aka.ms/credentialssupport link) and submit a ticket under Product Family: Learning and Service: Microsoft Credentials.
  3. If Pearson VUE was the exam provider
    • Pearson VUE can confirm that the exam was delivered successfully, but for missing certificates or access issues, Microsoft Credentials Support must resolve it.
If the certificate has been issued correctly, it can be viewed and downloaded from the Certification Dashboard, and the associated badge can be managed via the badging platform.
1 additional answer
  1. Deleted
