Pin Control Panel to taskbar
Phillip Richcreek 1,105 Reputation points
2026-06-08T01:11:30.4466667+00:00
I want to pin the Windows Control Panel to the taskbar. How can I accomplish that?
Windows for home | Windows 11 | Desktop, Start, and personalization | Task Bar
AI answer
2026-06-08T01:11:45.04+00:00
Use the Start menu entry for Control Panel and pin it from there.
  1. Select Start and open All apps.
  2. Find Control Panel in the list.
  3. Right-click Control Panel and select Pin to taskbar.
Alternatively, drag Control Panel from the Start menu to the taskbar to create a pinned icon.
0 additional answers
