OneDrive Installation Issue on macOS Ventura 13.7.8
Shulgin Alexei 25 Reputation points
2026-06-06T18:22:21.6866667+00:00
Good day,
Today I encountered a problem with OneDrive. It suddenly disappeared from my computer, even though I use it every day and all of my files are stored in the cloud.
I am using macOS Ventura 13.7.8. I tried downloading and installing the latest version of OneDrive directly from the Microsoft website, but I have been unable to complete the installation.
When I open the installer, I receive the following message:
"Microsoft OneDrive cannot be installed in this location. The Microsoft OneDrive installer does not allow this software to be installed here."
As a result, I cannot reinstall OneDrive or access my synchronized files through the application.
Could you please help me resolve this issue and advise me on the correct steps to reinstall OneDrive on my Mac?
Thank you very much for your assistance.
Have a great day.
Kind regards,
Microsoft 365 and Office | OneDrive | For home | MacOS
WF 15 Reputation points
2026-06-08T22:12:52.07+00:00
I had the same issue with my macOS Ventura 13.7.8 and I tried all the suggestions that Kai-H provided, but they didn't work for me.
What finally worked for me was when I downloaded an older version of the OneDrive installer (26.055.0323.0004).
1 additional answer
  1. Kai-H 27,135 Reputation points Microsoft External Staff Moderator
    2026-06-07T06:57:23.6966667+00:00
    Hi, Shulgin Alexei
    This usually happens when macOS still sees old OneDrive installation records or leftover OneDrive folders, even if the app itself has disappeared. It can also happen if the installer is being launched from a folder managed by iCloud, Dropbox, or another sync/backup service.
    Here are some suggestions you can try:
    First, move the OneDrive installer file out of Downloads. Put it somewhere simple, such as a temporary folder directly under your user folder, then open it from there. It is suggested that this can help when macOS Installer refuses a package because the file is sitting in a synced or protected location.
    Next, check for hidden leftovers. In Finder, select Go, then Go to Folder, and open:
    ~/Library/CloudStorage
    If you see old OneDrive folders there, move them to the Trash. Also check:
    ~/Library/Group Containers/
    ~/Library/Containers/
    and remove folders that clearly mention OneDrive or Microsoft OneDrive. Restart the Mac afterward.
    If you are comfortable using a helper app, it is recommended that you use AppCleaner to remove OneDrive completely, then restart and install again. This often catches hidden files that dragging the app to Trash misses.
    Note: This information is provided as a convenience to you. The app is not controlled by Microsoft. Microsoft cannot make any representations regarding the quality, safety, or suitability of any software or information found there. Please make sure that you completely understand the risk before retrieving any suggestions from the above app.
    Also open Disk Utility, select the internal drive, and confirm the format is APFS, not case-sensitive APFS. OneDrive can fail on unsupported or case-sensitive locations.
    If the standalone installer still gives the same message, try installing OneDrive from the Mac App Store instead. Since Ventura 13 is still within the OneDrive support range, this may bypass the package installer issue.
    Thank you for your patience in reading, I hope this information has been helpful to you.
    If the answer is helpful, please click "Accept Answer" and kindly upvote it. If you have extra questions about this answer, please click "Comment."
