When robux will restock?
Nasywa Salsabila 40 Reputation points
2026-06-06T03:40:00.69+00:00
it,s been a while since i always see that the robux has not restocked yet. will it be restocked or removed permanently?
Bing | Bing Apps | Use app feature
Mobile and desktop apps that bring Bing’s search, discovery, and personalization features to users across devices.Use app feature - Apply an application's functionalities and tools to achieve specific tasks.
Darhyl Amizola 50,060 Reputation points Independent Advisor
2026-06-06T04:17:49.6833333+00:00
Hey there! Nice to meet you!
Unfortunately, there is no set timeframe for replenishing out‑of‑stock codes, and it may take months or years. There have also been no announcements that Robux has been permanently removed from the Rewards Store.
In the meantime, I recommend saving your rewards points and checking the Rewards Store from time to time.
You can also provide your feedback regarding your issue on https://rewards.bing.com/
Click "Feedback" at the bottom right corner of the page > then submit your feedback.
Thank you for your understanding! Please let me know if you need anything else.
Best regards,
Darhyl
1 additional answer
  1. Nasywa Salsabila 40 Reputation points
    2026-06-06T04:21:22.82+00:00
    Alright then. Thank you so much. Hopefully it will be restocking asap!
