Edge is broken after safe mode
masseeker 40 Reputation points
2026-06-04T11:14:54.33+00:00
Today I wanted to test if remote desktop programs can launch in safe mode. Here is what I did.
  1. Enter safe mode with network.
  2. Try to launch rd programs and fail.
  3. Open Edge to check if network is working.
  4. Restart.
Then weird things happened:
  1. Edge profile is logged out.
  2. All web sites are logged out.
  3. All search engines in settings lost.
  4. Extension "iTab New Tab" is disabled.
  5. There is a message "managed by your organization" at the bottom left on extension page.
  6. Some of my extensions have a yellow icon at bottom right which says "unpacked extension" which is incorrect because they are installed from microsoft extension site.
  7. Every time edge launches there is a "extension run in developer mode" message while the developer mode switch is off.
I tried resync profile, remove readonly attribute of "%LOCALAPPDATA%\Microsoft\Edge\User Data\Default"(which has a size of 1.61GB) and restart but none of these works. Passwords and other settings remain unchanged (At least the ones I checked).
What I worry about is that my system may has been modified in other places other than Edge.
Microsoft Edge | Profile, sync, and sign in | Windows 11
Lychee-Ng 28,910 Reputation points Microsoft External Staff Moderator
2026-06-05T11:19:23.8933333+00:00
Hi masseeker,
I can understand how worrying it is to see Edge looks partially “managed”, especially after booting into Safe Mode. The good news is that this points more toward Edge profile/policy corruption, than malware silently modifying the entire system.
The AI answer is actually fairly solid here, especially the temporary-profile test, because that is the fastest way to determine whether this is Edge profile corruption, or something system-wide. I would only add a few other points you can consider:
  1. Open edge://policy > see if there are unexpected policies listed: If the page is empty or only shows a few normal entries, that is reassuring. If you suddenly see many/unknown ones, then something modified Edge policy storage.
  2. Temporarily remove iTab New Tab extension: it has a reputation for modifying browser behavior and search-related settings. Even if intentionally installed, I would remove it first before troubleshooting further.
Personally, I do not think this looks like broad Windows corruption, since if it was damaged, you would usually also see more broken signs outside Edge. However, your concern is totally reasonable, so here’s some other things you can check to make sure:
  • Run Windows system integrity checks:
    • Press Win + X > open PowerShell / Terminal (Admin)
    • Run: DISM /Online /Cleanup-Image /RestoreHealth
    • Run: sfc /scannow > let it finish > restart PC.
  • Check whether Safe Boot is still configured
    • In the same command window, run bcdedit
    • Make sure there’s no safeboot in the boot entry.
  • (Deeper clean) Reinstallation repair, keeping files and apps:
    • Open Settings > System > Recovery > Fix problems using Windows Update
    • Click Reinstall now > follow the onscreen instructions to reinstall Windows.
Disclaimer: This reinstallation can fix update issues without removing your files or applications. However, we always recommend that if you have important data, you should back it up.
If possible, consider checking Event Viewer > Windows Logs > Application and look for any entries around the time you entered/exited Safe Mode. That can sometimes confirm if there’s any corruption.
AI answer
2026-06-04T11:15:06.06+00:00
Edge itself is likely corrupted, not the whole system. Safe Mode can interfere with user profiles and extensions, and a damaged Edge profile or install can cause exactly the symptoms described (sign-out, extensions treated as “unpacked,” “managed by your organization” banner).
Use the following sequence to repair Edge and the profile.
  1. End all Edge processes
  • Press Ctrl+Shift+Esc to open Task Manager.
  • End every msedge.exe process.
  • Close Task Manager.
  1. Start Edge with a temporary test profile
  • Open Command Prompt.
  • Run:
      "C:\Program Files (x86)\Microsoft\Edge\Application\msedge.exe" --user-data-dir="%TEMP%\edge-test-profile"
  • Check whether:
    • The “managed by your organization” message disappears.
    • Extensions behave normally.
If the test profile is clean, the original profile is corrupted.
  1. Create a fresh Edge profile
  • Close all Edge windows.
  • Go to %LOCALAPPDATA%\Microsoft\Edge\User Data.
  • Rename the Default folder to Default.old.
  • Start Edge normally; a new Default profile folder is created.
  • Sign back into the Edge profile and let sync restore data.
  • If Edge is stable, optionally copy specific data (for example, Bookmarks) from Default.old into the new Default folder.
  1. Repair the Edge installation If problems persist even with a new profile:
  • Make sure Edge is closed for all users.
  • Go to Start > Settings > Apps > Installed apps.
  • Select Microsoft Edge > Modify > Repair.
  • Confirm the UAC prompt and stay connected to the internet while repair runs. Browser data and settings should not be affected.
  1. General system checks (optional) If Edge still behaves abnormally after the above:
  • Restart the computer once more.
  • Ensure Windows Security or other security software is up to date and run a malware scan.
If the temporary profile and new profile both work normally, the issue is confined to the old Edge profile and does not indicate broader system modification.
0 additional answers
