Problem to proceed to pearson vue portal
Jaime Manuel Padrón Cano 0 Reputation points
2026-06-04T00:44:04.14+00:00
Hey comunity, I am getting this error while trying to access to pearson vue portal, do you know what can I do here? has anyone faced something similiar?
    2026-06-04T00:44:17.4033333+00:00
    The “unexpected error” when accessing the Pearson VUE portal is commonly caused by an account-level block on the Pearson VUE side, often after multiple failed payment attempts.
    To resolve this, contact Pearson VUE support so they can check and unblock the account if needed. Use the support contact path provided via Microsoft Certification support and Pearson VUE:
    1. Go to the Microsoft Credentials support entry point: https://aka.ms/CertificationSupport (as referenced in the community answers).
    2. From there, follow the guidance to reach Pearson VUE support for Microsoft exams and request that they review and remove any “ERROR_VUE_WIDE_BLOCK” or similar account block.
    If the error persists even after Pearson VUE confirms the account is clear, open a case with Microsoft Credentials support so they can investigate from the Microsoft side.
