Support + troubleshooting solution fails to load on Azure Portal
Austin.Wang (王世豪) 20 Reputation points
2026-06-03T05:28:50.9933333+00:00
Using Support + troubleshooting with Container App deployment causes the page to get stuck on loading before going blank. The Container App itself also cannot be displayed on Azure Portal because it gets stuck on loading.
Azure Container Apps
An Azure service that provides a general-purpose, serverless container platform.
Siddhesh Desai 8,210 Reputation points Microsoft External Staff Moderator
2026-06-03T06:06:25.65+00:00
Hi @Austin.Wang (王世豪)
Thank you for reaching out to Microsoft Q&A.
As per our discussion on Teams:
The issue was due to the known platform level service issue https://app.azure.com/h/0YN_-CGG/c8d710
which was resolved within 24 hours.
If the resolution was helpful, kindly take a moment to click on 210246-screenshot-2021-12-10-121802.pngand click on Yes for was this answer helpful. And, if you have any further query do let us know.
0 additional answers
