Device Manager shows a constant Unknown USB Device (Port Reset Failed) loop
Daniel Ismail 20 Reputation points
2026-06-03T02:24:50.3933333+00:00
Hi all, my PC is making the Windows "device connected" followed by "device disconnected" sound effects every 10 seconds on a loop. I opened Device Manager and watched it refresh constantly, showing a yellow triangle that says "Unknown USB Device (Port Reset Failed)." I have absolutely nothing plugged into my USB ports except my mouse and keyboard.
Windows for business | Windows 365 Business
Tracy Le 13,050 Reputation points Independent Advisor
2026-06-03T03:17:50.8666667+00:00
Hi Daniel Ismail,
I understand how annoying that constant connect and disconnect sound loop can be, especially when you do not have any external devices plugged into your USB ports. The Unknown USB Device (Port Reset Failed) error with a yellow triangle in Device Manager usually indicates a power instability or a hardware level glitch within the internal USB root hub controller or an internal component like a webcam or card reader.
To fix this, you should right click the Start menu, open Device Manager, expand the Universal Serial Bus controllers section, right click on the specific hub showing the error and select Uninstall device before restarting your computer to force Windows to cleanly reinstall the driver.
If the refreshing loop persists after the reboot, it often means the system is failing to properly cut power to the glitched internal port during idle states. You can resolve this by double clicking your Generic USB Hub and USB Root Hub devices in that same section, navigating to the Power Management tab and unchecking the option that allows the computer to turn off this device to save power.
If this configuration stabilizes your USB controller and stops the continuous loop of connection sound effects, please accept this answer to help other community members facing the same hardware glitch.
0 additional answers
