Cpu Surface book 3 limitado en bateria a 0.40ghz
Luis Fernández 0 Reputation points
2026-06-02T17:20:11.95+00:00
Tengo la surface book 3, 15" i7-1065G7 1.30ghz 32gb ram nvidia quatro rtx 3000 with Max-Q Designs, windows 11 Pro instalado desde 0, el problema es que cuando está desconectada de la corriente el procesador baja a 0.40ghz y es demasiado lenta, ya e he instalado driver, actualizado windows, revisado las baterias y todo esta en orden, con el programa throtlestop he conseguido que el cpu suba a 1.5 ghz cuando esta en bateria. pero entiendo que esto no debe ser asi. cuando está conectada a la corriente el cpu sube a 3.9ghz. necesito resolver este inconveniente. tiene su cargador original nuevo.
Surface | Surface Book | Performance and maintenance
  1. S.Sengupta 32,351 Reputation points MVP Volunteer Moderator
    2026-06-03T01:30:01.4533333+00:00
    Download Surface Book 3 Drivers and Firmware
    Open CMD as Administrator and run:
    powercfg /duplicatescheme e9a42b02-d5df-448d-aa00-03f14749eb61
    This restores the Ultimate Performance plan.
    Then go to Control Panel → Power Options and select Ultimate Performance.
    Also set "On battery" processor minimum to at least 50% in Advanced Power Settings:
    Power Options → Change plan settings → Change advanced → Processor power management → Minimum processor state
    The core problem is the Quadro RTX 3000 running on battery. You need to tell Windows to use the Intel Iris Plus iGPU when unplugged:
    Go to Settings → Display → Graphics
    For each app that doesn't need GPU power, set it to Power saving (iGPU)
    For the default, set it to Power saving when on battery
    NVIDIA Control Panel:
    Go to Manage 3D Settings → Global Settings
    Set "Preferred graphics processor" to Intel integrated graphics
    This alone can stop the firmware from throttling the CPU---
