Laptop fan spins loudly at max speed even when the device is completely asleep
Sofia Rossi 40 Reputation points
2026-06-02T15:58:48.6733333+00:00
Dear team,
I put my laptop to sleep last night, closed the lid, and put it on my desk. An hour later, I heard a loud whirring noise and realized the laptop fans were screaming at 100% speed, even though the device was supposed to be suspended. The chassis felt extremely hot to the touch. Why is Windows triggering heavy processing workloads while the lid is closed and sleeping?
Windows for business | Windows 365 Enterprise
Harry Phan 33,320 Reputation points Independent Advisor
2026-06-02T16:28:27.1266667+00:00
Hi Sofia,
Your laptop isn’t actually going into the old “deep sleep” mode; it’s using Modern Standby, which keeps the system semi‑active so it can run updates or background tasks even with the lid closed. That’s why the fans spin up and the device gets hot. You can confirm this with powercfg /a,if you see “Standby (S0 Low Power Idle)” instead of “S3 Sleep,” that’s the cause. The practical fix is to disable wake timers in advanced power settings and turn off network activity during standby in your network adapter’s power management tab. Updating BIOS and chipset drivers from your laptop’s manufacturer is also important, since many vendors release patches to stop overheating during Modern Standby.
Harry.
0 additional answers
