Bluetooth Headset Connection Issue
Abduallah Arafa 0 Reputation points
2026-06-01T12:04:38.2633333+00:00
I would like to report an issue with my Bluetooth headset. For some time now, when I connect it to my device, it shows as connected but no sound is heard. In some cases, audio works for about two seconds after connection, then stops completely despite the headset still appearing connected.
I have already tried checking the Windows settings, and everything appears to be correct. I also checked for updates, but there were no new updates available. In addition, I restarted the device several times and even tested it on a new Windows installation, but the problem still remains.
The issue is intermittent, as the headset sometimes works properly immediately after connection, but in many cases, it does not work at all.
Windows for business | Windows Client for IT Pros | Devices and deployment | Set up upgrades and drivers
    2026-06-01T12:05:21.81+00:00
    Follow these steps on the affected Windows device to troubleshoot the Bluetooth headset that shows as connected but has no sound or stops after a few seconds:
    1. Run the Bluetooth troubleshooter
      • On Windows 11 or Windows 10, open the Get Help app and run the Bluetooth troubleshooter using the built‑in entry:
        • This runs diagnostics and attempts to automatically fix Bluetooth audio issues such as “connected but no sound.”
    2. Verify output device and volume
      • Click the Sound icon in the taskbar and ensure the Bluetooth headset is selected as the audio output device.
      • Go to Start > Settings > System > Sound.
      • Under Output (Windows 11) or Choose your output device (Windows 10), select the Bluetooth headset.
      • Confirm volume is not muted and is set to an audible level.
    3. Adjust audio format
      • Windows 11:
        1. Go to Start > Settings > Bluetooth & devices > Devices.
        2. Select the Bluetooth headset, then select Advanced sound properties.
        3. Under Output settings, set Format to 2 channels, 16 bit, 48000Hz (DVD Quality).
      • Windows 10:
        1. Right‑click the Sound icon in the taskbar and select Sounds.
        2. Open the Playback tab, select the Bluetooth headset, and click Properties.
        3. On the Advanced tab, under Default Format, select 2 channel, 16 bit, 48000 Hz (DVD Quality), then Apply and OK.
    4. Unpair and re‑pair the headset
      • Windows 11:
        1. Go to Start > Settings > Bluetooth & devices.
        2. Locate the headset, select More options (…) > Remove device.
        3. Select Add device and pair the headset again.
      • Windows 10:
        1. Go to Start > Settings > Devices > Bluetooth & other devices.
        2. Select the headset and choose Remove device.
        3. Select Add Bluetooth or other device and pair it again.
    5. Power‑cycle Bluetooth
      • Windows 11:
        2. Turn Bluetooth off, wait at least 10 seconds, then turn it on again.
        3. Reconnect the headset and test audio.
      • Windows 10:
        2. Turn Bluetooth off, wait 10 seconds, then turn it on.
    6. Update Bluetooth drivers
      • If the issue started or worsened after a Windows upgrade or update, update the Bluetooth adapter driver:
        1. Select Start > Device Manager.
        2. Expand Bluetooth, select the Bluetooth adapter (may include “radio” in the name).
        3. Right‑click and choose Update driver > Search automatically for updated driver software.
        4. Complete the wizard, then restart the device if prompted and test the headset again.
    7. Confirm A2DP support on the headset
      • Check the headset documentation or manufacturer’s website to confirm it supports the A2DP profile (required for high‑quality audio streaming). If it does not support A2DP, Windows may connect for control but not stream audio reliably.
    8. Ensure Windows is fully updated
      • Windows 11:
        1. Go to Start > Settings > Windows Update.
        2. Select Check for updates and install all available updates.
      • Windows 10:
        1. Go to Start > Settings > Update & Security > Windows Update.
        2. Select Check for updates and install any available updates.
    9. Restart after changes
      • After driver updates or major Bluetooth configuration changes, restart the PC: Start > Power > Restart, then reconnect the headset and test.
    If the issue persists after these steps, collect details such as the exact headset model, Bluetooth adapter model, and whether other Bluetooth audio devices show the same behavior, then proceed with more targeted Bluetooth troubleshooting using the guidance in Fix Bluetooth problems in Windows.
  2. Harry Phan 31,210 Reputation points Independent Advisor
    2026-06-01T12:36:59.4133333+00:00
    Hey Arafa, I’ve run into the same kind of Bluetooth issue myself, and it usually comes down to Windows picking the wrong audio profile. Most headsets register both a stereo (A2DP) and a hands‑free profile, and if Windows defaults to the hands‑free one you’ll see it connect but get no sound or audio that cuts out. The fix that’s worked for me is to go into Sound settings and make sure the headset is set to the stereo output, then disable the hands‑free service under the device’s Bluetooth properties. If that doesn’t stabilize it, reinstalling the Bluetooth driver from your device manufacturer instead of relying on Windows Update often clears up the problem.
    Harry.
