Use the built-in Windows audio troubleshooting steps to restore laptop output sound.
- Check the selected output device and volume
- On Windows 11:
- Select the Speakers icon on the taskbar.
- Select the arrow next to the volume slider to open the list of audio devices.
- Choose the correct output device (laptop speakers or the device you want to use).
- Open the Volume mixer from the same menu and make sure none of the volume sliders are muted or set to 0.
- On Windows 10:
- Select the arrow to open the list of audio devices.
- Make sure audio is playing to the preferred device (laptop speakers or headphones).
- On Windows 11:
- Check physical connections and basic controls (if using external speakers/headphones)
- Ensure all audio cables are firmly plugged in and in the correct jack.
- Confirm speakers/headphones are powered on.
- Make sure hardware mute buttons or dials on the device are not enabled and volumes are turned up.
- If headphones are plugged in, unplug them and test the laptop speakers.
- Verify sound settings and that devices are enabled
- Windows 11:
- Right-click the Speakers icon on the taskbar.
- Open the Volume mixer and ensure no devices/apps are muted.
- Go to Start > Settings > System > Sound.
- Under Advanced, select More sound settings.
- On the Playback tab, select the laptop speakers (or desired device), choose Properties, and ensure Device usage is set to “Use this device (enable)”.
- Windows 10:
- Right-click the Speakers icon > Open Volume mixer and unmute any muted devices.
- Select the audio device > Device properties and ensure the Disable checkbox is cleared.
- Windows 11:
- Set the correct default audio device
- Windows 11:
- Start > Settings > System > Sound.
- In Output, select the device to use for playback; this also sets it as default.
- If using an external monitor without speakers, make sure that monitor is not selected as the default output.
- Windows 10:
- In the search box, type control panel and open it.
- Go to Hardware and Sound > Sound.
- On the Playback tab, right-click the correct audio device (laptop speakers or desired output) and select Set as Default Device, then OK.
- Windows 11:
- Install Windows Updates and restart
- Windows 11:
- Start > Settings > Windows Update > Check for updates.
- Install available updates and restart the PC.
- Windows 10:
- Start > Settings > Update & Security > Windows Update > Check for updates.
- Install updates, then restart.
- Windows 11:
- Update or reinstall the audio driver
- Update driver (Windows 10 and 11):
- In the search box, type device manager and open it.
- Expand Sound, video and game controllers.
- Right-click the audio device (e.g., laptop speakers/Realtek) > Update driver.
- Choose Search automatically for drivers (Windows 11) or Search automatically for updated driver software (Windows 10) and follow the prompts.
- If no newer driver is found, download the latest audio driver from the laptop manufacturer’s support site and install it.
- Reinstall driver if updating doesn’t help:
- In Device Manager, expand Sound, video and game controllers.
- Right-click the audio device > Uninstall device.
- On Windows 11, check Attempt to remove the driver for this device.
- On Windows 10, check Delete the driver software for this device.
- Select Uninstall and restart the PC. Windows will reinstall the audio driver automatically.
- If issues started after a Windows Update on Windows 10, use Device Manager > sound device Properties > Driver tab > Roll Back Driver and follow the prompts.
If sound still does not work after these steps, the issue may be hardware-related and may require device manufacturer support.
- Fix sound or audio problems in Windows
- No audio with Windows 11 - Microsoft Q&A
- cannot increase volume even if trouble shooter updates it - Microsoft Q&A
- How to fix this. no audio device is installed - Microsoft Q&A
- My audio inputs and outputs suddenly disappeared, how do i fix this? - Microsoft Q&A
- I have no sound on an new LG Gram laptop - Microsoft Q&A
