how do I create a study plan?
Steve O'Brien 0 Reputation points
2026-06-01T05:14:22.9033333+00:00
I am trying to add an item to a plan, but it says I do not have any plans. how do I create a plan?
    2026-06-01T05:14:34.0866667+00:00
    On Microsoft Learn, a study plan is created as a Plan. If the message says there are no plans yet, first create one, then add items to it.
    To create a Plan on Microsoft Learn:
    1. Sign in to Microsoft Learn and ensure the Learn profile is active.
    2. Create or copy a Collection that contains the learning content to use:
      • Follow the steps in "Create and manage Microsoft Learn Collections" to build a Collection with the modules, learning paths, or other Learn content.
    3. Convert the Collection to a Plan:
      • Go to the profile’s Collections page.
      • Select the Collection to use.
      • Use the option to copy/convert this Collection into a Plan.
      • When the Plan is created, the Collection’s title, description, and section descriptions are copied into the Plan.
      • Sections in the Collection become Milestones in the Plan.
    4. Edit the Plan:
      • Add or edit Milestones (reorder, add, delete, or move items between milestones).
      • Optionally add Learning outcomes (skills learners will gain).
      • Optionally add Days to milestone (recommended number of days to complete each milestone).
    5. Publish the Plan and then add content:
      • From any Learn content page, select the + icon.
      • Choose the Plans tab.
      • Select the Plan just created and select Save.
    Once the Plan exists, the “no plans” message will no longer appear when adding items; the Plan will be available in the Plans list.
