Combine VLOOKUP & HLOOKUP, Multi Input, Single Output
Gano.M 20 Reputation points
2026-05-29T13:00:38.6533333+00:00
Hey,
I'm trying to create a table for the following:
I have 3 sets of Items, and each item has a different specification. Some of the specifications are the same even though they mean different things and they can't be changed.
My final table has three columns.
Column 1 (INPUT) = Item
Column 2 (INPUT) = Specification
Column 3 (OUTPUT) = Size
I need help with a formula for Column 3. Everything I've tried returns an error. I've attached a picture here to show you what I mean.
Thank you.
AI answer
2026-05-29T13:01:07.8666667+00:00
Use a single lookup formula that combines the item and specification to return the size. A robust approach is to use INDEX with MATCH on a helper range that uniquely identifies each item/spec combination.
Assume:
  • Column A: Item (input)
  • Column B: Specification (input)
  • A lookup table somewhere else with:
    • Column F: Item
    • Column G: Specification
    • Column H: Size
Then in Column C (Size output), use:
=INDEX($H$2:$H$100,
       MATCH(1,
             ($F$2:$F$100=A2)*($G$2:$G$100=B2),
             0))
Enter this as a dynamic array formula in newer Excel, or as a legacy array formula (Ctrl+Shift+Enter) in older versions.
Explanation:
  • ($F$2:$F$100=A2) checks for matching item.
  • ($G$2:$G$100=B2) checks for matching specification.
  • Multiplying them creates a combined condition (both must be TRUE).
  • MATCH(1, …, 0) finds the row where both conditions are met.
  • INDEX returns the corresponding size.
This avoids needing to literally combine VLOOKUP and HLOOKUP and instead uses the recommended INDEX/MATCH pattern for multi-criteria lookups.
0 additional answers
