System tray icons disappeared
Ilija Pravilovic 25 Reputation points
2026-05-29T11:40:56.58+00:00
My icons from the right side of the taskbar are missing. I can't see any settings in taskbar behaviour or Time & date to return them back. I tried restarting windows explorer, run explorer shell, cleared cashe items from TrayNotify and nothing helps. When I install the latest updates, I must use bitlocker to switch on my computer. Anyone had similar experience?
Ilija
Windows for home | Windows 11 | Display and graphics
DaveM121 935.7K Reputation points Independent Advisor
2026-05-29T12:15:10.9033333+00:00
Are all icons on the system tray on the right side of your taskbar missing, please provide a screenshot of the problem, this is most likely caused by a Windows update.
Open the Settings app, go to Windows Update - Update History, what is the KB number of the latest Windows updates installed on your system.
0 additional answers
