An Azure service that provides hosted, universal storage for Azure app configurations.
Hi ,
Thanks for reaching out to Microsoft Q&A.
This is typically a client-side loading issue in the azure portal (ReactView modules failing to load), not a backend resource problem. In Edge, it is usually caused by cached/corrupted portal assets, blocked scripts, or extension interference. Fix it by doing a hard refresh (Ctrl+F5), clearing browser cache/storage for the portal, and disabling extensions (especially ad blockers or security plugins). Also ensure 3rd party cookies and local storage are not blocked, and try opening the portal in InPrivate mode to validate. If it still happens intermittently, it is often due to transient CDN/module load failures in the portal itself, and there is little to fix beyond retrying or switching to another browser session.
Please 'Upvote'(Thumbs-up) and 'Accept' as answer if the reply was helpful. This will be benefitting other community members who face the same issue.
