how to make a fixlist, using FRST.64, with the correct issues listed and who to send it to, to get the fixlist that works.
Magnus 0 Reputation points
2026-05-27T15:04:13.3466667+00:00
I've for the past week or so had issues with something called "MaleficAms.W", which is apparently a virus, that opens windows powershell and is generally just not good. However it hasnt really changed my pc much other than the fact everything is slower than usual.
After searching through forums, a lot of people mentioned FRST.64 to use for scanning and finding the issues. I did just that but I haven't gotten an answer on how to solve my issue, only what it was.
And after searching the internet some more I find out I have to make this fixlist and send it to a malware analyst to get me a code that can solve my specific pc problem.
The issue:
How do I know all the things I should have in the fixlist + how do I make it?
Who do I send it to/how do I get in contact with a "malware analyst" that's trustworthy and can help me find a solution?
Hope someone can help because all I've been getting told by tech friends ect. Is that I might have to pc wipe/reset, which I obviously would like to avoid if possible.
Microsoft Security | Microsoft Defender | Other
    2026-05-27T15:04:52.08+00:00
    FRST and custom fixlists are not Microsoft tools and are not covered in the provided context. Guidance for creating or sending FRST fixlists is therefore out of scope.
    For malware such as MaleficAms.W on Windows, the supported options in the context are:
    1. Run Microsoft’s malware removal tools
    • Run the built-in Malicious Software Removal Tool:
      1. Press Windows logo key + R.
      2. Type %windir%\system32\mrt.exe and select OK.
      3. Allow the program to make changes if prompted.
      4. Choose a full scan and follow the prompts to remove detected malware.
    • If no antivirus is installed or existing AV is damaged, use Microsoft Safety Scanner, which can clean viruses from the computer. (See the “Microsoft Safety Scanner” references in the context.)
    1. Use Microsoft Defender Antivirus and keep definitions updated
    • Ensure Microsoft Defender is enabled and run a full scan. A full scan checks all locations where malware can hide.
    • Make sure security intelligence (definitions) is current:
      • Open Windows Security → Virus & threat protection.
      • Under Virus & threat protection updates, select “Check for updates”.
    • If Defender cannot update, manually install the latest definitions from the definitions page referenced in the context.
    1. If threats are only partially removed
    • When a threat is reported as “partially removed”, run a full scan with the Malicious Software Removal Tool as above.
    • Restart the PC and manually install the latest Windows and Defender updates.
    • If problems persist, use advanced troubleshooting guidance or Microsoft Defender Offline as referenced in the context.
    1. If malware caused irreversible changes
    • If the system remains unstable or slow after cleaning, Windows may have irreversible changes.
    • Back up important files to an external location (for example, OneDrive or external drive).
    • Use Windows recovery options (Reset this PC, restore, or reinstall) as described in the recovery options article referenced in the context. Prefer “Keep my files” first to avoid data loss.
    1. Where to get trustworthy help
    • Use official Microsoft support channels and communities:
      • Microsoft Community Virus and Malware website for community help.
      • Contact Microsoft Support page for direct assistance.
    • If a file is suspected to contain malware, submit it for analysis using the official file submission portal referenced in the context.
    These steps avoid reliance on third‑party custom scripts and keep remediation within supported Microsoft tools and channels.
