Connectng to Databricks MCP server from Power Platform (Copilt Studio)
Ahmed Shamim 20 Reputation points
2026-05-27T14:31:48.3666667+00:00
Hi all,
We are trying to connect to the Databricks Genie MCP server from a MS Copilot Studio Agent, while also supporting end user authentication (OAuth2).
Question 1: I found this documentation: https://learn.microsoft.com/en-us/azure/databricks/integrations/msft-power-platform-setup, where Databricks can be added as a connection. This seems to require Premium License , question is just needed for the users of the apps that use this creation?
Question 2 : I see we can also add the MCP server as a tool for the agent , using a streamable HTTP server endpoint, and configure Oauth2, does this also have any special licensing requirements?
Microsoft Copilot | Microsoft 365 Copilot | Development
    2026-05-27T14:32:00.54+00:00
    Question 1: The context only specifies how to create an Azure Databricks connection in Power Apps/Power Automate and then use it from Copilot Studio; it doesn’t state any licensing details or requirements (including Premium) for that connector or for users of apps/agents that use it. No licensing information is available in the provided material.
    Question 2: Similarly, the context describes two ways to connect MCP servers to Copilot Studio agents:
    • Using the MCP onboarding wizard directly in Copilot Studio.
    • Creating a custom MCP connector in Power Apps and then using it in Copilot Studio.
    It also shows how to configure OAuth 2.0 (including manual configuration) for MCP servers and how to complete the setup and test the connection. However, there is no information about any specific or additional licensing requirements for using an MCP server (including a Databricks Genie MCP server) with OAuth 2.0 from Copilot Studio.
    The available documentation only covers configuration and troubleshooting, not licensing.
