Disable recall without disabling Copilot
David deLesdernier 0 Reputation points
2026-05-24T12:41:53.09+00:00
How do I disable Recall without disabling Copilot?
Microsoft Copilot | Windows Copilot | Feature
    2026-05-24T12:42:03.87+00:00
    Recall can be disabled independently while keeping Copilot available.
    On a personal (unmanaged) Copilot+ PC:
    1. Turn off saving snapshots only:
      • Open Settings > Privacy & security > Recall & snapshots.
      • Set Save snapshots to Off. This stops new snapshots from being saved but keeps Recall installed and Copilot available.
    2. Remove the Recall feature entirely (optional, more drastic):
      • Open Start and search for Turn Windows features on or off.
      • In Windows Features, clear the Recall checkbox.
      • Restart the PC. Any existing snapshots are deleted when Recall is removed. Copilot remains available because Recall is an optional Windows feature separate from Copilot.
    On a managed (work or school) device:
    • IT admins control whether Recall is present and whether users can save snapshots via the Allow Recall to be enabled and Turn off saving snapshots for Recall policies.
    • Even when admins allow Recall, saving snapshots still requires explicit user opt‑in; admins cannot start snapshotting on behalf of users.
    • If the Save snapshots toggle is greyed out or Recall is removed, this is enforced by policy and must be changed by the admin.
    For command-line removal on a managed device where Recall has been enabled:
    • An individual user can run (with appropriate rights):
        Disable-WindowsOptionalFeature -Online -FeatureName "Recall" -Remove
      This removes Recall and its snapshots from that device without disabling Copilot.
