Container registry connection error
Chonnimit Eksumpunthapap 0 Reputation points
2026-05-21T06:39:27.6666667+00:00
i can't login, pull or view status in azure portal.
Azure Container Registry
An Azure service that provides a registry of Docker and Open Container Initiative images.
    2026-05-21T08:11:39.8233333+00:00
    Will Smith - There is an ongoing service degradation affecting Azure Resource Manager (ARM) and Azure Container Registry (ACR).
    At present, customers in Southeast Asia and multiple other regions may experience:
    Increased error rates
    Request timeouts
    Intermittent failures (including 504 Gateway Timeout / Service Unavailable responses)
    Our engineering team has investigated the issue and working on mitigation efforts to restore normal service as quickly as possible. Issue should be mitigated now
    We will continue to keep you informed as we receive further updates. In the meantime, we recommend retrying failed operations, as some requests may succeed intermittently.'
    If you have any further queries, let me know. If the information is helpful, please click on Upvote and Accept Answer on it.
