trying to turn on the f5 thru f7 keys for volume?
winston lehr 0 Reputation points
2026-05-21T02:39:09.4366667+00:00
every time i press f5 thru f7 to adjust volume on my hp touch desktop. it just switches to the search bar and other tabs. there is no fn lock or anything on here. i have repeated hit fn and esc to no avail. and when I restart the pc and hit f10 for the setting the bios settings are locked so I can't even adjust. please help. I am using the wireless keyboard and mouse as well that came with the pc. thank you in advance. and this is after i turned off the carot browsing
Windows for home | Other | Input and language
    2026-05-21T02:39:20.8266667+00:00
    On many modern keyboards, the top-row keys (including F5–F7) have two modes:
    • Special-key mode (volume, brightness, etc.)
    • Standard function-key mode (F1–F12 for app shortcuts like Search)
    The issue described indicates the keyboard is currently in standard function-key mode, so F5–F7 are being sent as normal function keys instead of volume keys.
    Use these steps depending on the keyboard type:
    1. If the keyboard has an Fn key that toggles function mode:
      • Press the Fn key once to switch modes. On some Microsoft/Surface keyboards, a light on the Fn key indicates function mode is locked; turning that off returns the top row to special-key behavior (volume, etc.).
      • Then press F5–F7 again to see if they now control volume.
    2. If the keyboard has an F Lock key:
      • Press F Lock to toggle between standard F1–F12 functions and the alternate commands (such as volume, media, etc.).
      • When F Lock is off, alternate functions work; when on, standard F1–F12 functions work.
    3. If using a Surface Keyboard or similar Microsoft keyboard:
      • The top row acts as special keys (volume, brightness, etc.) unless the Fn key is enabled (locked).
      • Press Fn to lock/unlock function mode. When the Fn light is on, the keys act as F1–F12; when off, they act as special keys like volume.
    If none of these keys (Fn/F Lock) exist or respond, test with another USB or wireless keyboard. If the second keyboard’s volume keys work correctly, the original keyboard may require vendor-specific software or may have a hardware/firmware limitation that needs to be adjusted using HP’s tools rather than Windows settings.
