Custom claims provider (TokenIssuanceStart) not invoked during External ID user sign-in — endpoint receives zero requests despite ClaimsMappingPolicy attached
Tony Garrett 0 Reputation points
2026-05-20T23:07:05.1033333+00:00
UPDATE (after extensive Graph-side verification):
POST /identity/customAuthenticationExtensions/validateAuthenticationConfiguration
returns { errors: [], warnings: [] } for the current configuration.
GET /servicePrincipals/{id}/claimsMappingPolicies returns the policy
correctly attached.
GET /identity/authenticationEventListeners shows the TokenIssuanceStart
listener registered with the correct customExtension reference.
The sign-in flow now correctly requests an access-token scope
(api://{api-app-id}/SDLC.Access) so TokenIssuanceStart should fire.
However:
  • App Insights Live Metrics confirms zero inbound requests to the endpoint during sign-in.
  • jwt.ms shows AADSTS1100001 / 1003011 with handler numberOfAttempts=0.
  • Microsoft's own validateAuthenticationConfiguration endpoint returns no errors or warnings for this exact configuration.
New correlation IDs:
  • xxxxxxxx (00:07:24 UTC, 2026-05-21)
  • xxxxxxxxx (00:18:11 UTC, 2026-05-21)
What configuration step might cause numberOfAttempts=0 while the
configuration validator returns no errors? Is there a tenant-level
consent or first-party service principal permission grant that isn't
surfaced in either the portal or the validator that's required before
TokenIssuanceStart custom extensions will fire in CIAM tenants?
Summary
Microsoft Entra External ID custom authentication extension registered for
the TokenIssuanceStart event is not being invoked during user sign-in. The
endpoint is reachable and returns 200 on direct POST, but App Insights and
the App Service raw HTTP log show zero inbound requests during real sign-ins.
Three successful sign-ups through the published user flow have issued tokens
without ever calling the enrichment endpoint.
Environment
  • Tenant type: Microsoft Entra External ID (workforce-style customer tenant)
  • Application: ASP.NET Core 9 API on Azure App Service
  • Endpoint: HTTPS, public, validates OAuth bearer per Microsoft docs
  • Direct POST to the endpoint with a valid bearer returns 200 with a properly shaped onTokenIssuanceStart response (verified with curl)
Configuration verified
  • Custom authentication extension registered, event type TokenIssuanceStart
  • Extension references a separate app registration as the resource app
  • acceptMappedClaims=true set on the API application manifest
  • ClaimsMappingPolicy created with the claim schema entry pointing at the custom claims provider
  • ClaimsMappingPolicy attached to the API's service principal via Microsoft Graph (the Azure portal UI does not persist OIDC policy assignment, so Graph was required)
  • App registration has the required API permissions and admin consent granted
  • The 99045fe1-... first-party service principal is present in the tenant
  • Custom extension's app has the CustomAuthenticationExtension.Receive.Payload permission consented
Observed behavior
During real user sign-in through the user flow:
  • Sign-in completes and a token is issued
  • The token contains the user's standard claims
  • The token does NOT contain the claim that should have been added by the custom claims provider
  • App Insights for the endpoint's App Service shows zero requests during the sign-in window
  • App Service raw HTTP log (Diagnose and solve problems → Web app down / Application Logs) also shows zero inbound requests
  • Sign-in Diagnostic for the affected sign-ins returns no actionable guidance
  • The "azureSubErrorCode" field in the diagnostic UI renders as the literal placeholder string {azureSubErrorCode} rather than an actual sub-code, which appears to be a portal bug
Error codes observed where present
  • AADSTS1100001
  • AADSTS1003011
Ruled out
  • requestedAccessTokenVersion: External ID forces v2, no override needed
  • Missing first-party SP (99045fe1-...): present in tenant
  • Microsoft Graph permission gap: consent granted, verified
  • Missing claims-mapping policy: policy exists and is attached via Graph
  • Missing event listener registration: registered and visible in the portal
  • App Insights sampling hiding requests: ruled out via raw HTTP log
Questions
  1. What additional configuration could cause the TokenIssuanceStart event listener to silently no-op for a properly-registered custom claims provider with a Graph-attached ClaimsMappingPolicy?
  2. Is there a tenant-level toggle, feature flag, or licensing requirement for custom claims providers in External ID that is not surfaced in the public docs?
  3. Are AADSTS1100001 and AADSTS1003011 documented anywhere with externally-actionable guidance? The current Sign-in Diagnostic does not surface a sub-code.
  4. What is the supported way to verify, end-to-end, that a custom claims provider is being invoked at all during a user flow sign-in (short of waiting for log entries that never arrive)?
Any pointer to additional diagnostic surfaces I have not checked would be
appreciated.
Microsoft Security | Microsoft Entra | Microsoft Entra External ID
    2026-05-20T23:07:31.2833333+00:00
    For a TokenIssuanceStart custom authentication extension that never fires, the supported diagnostics and configuration checks are limited to what is surfaced through the extension configuration, REST API validation, and Microsoft Entra sign-in logs.
    From the documented behavior:
    • When a custom claims provider is configured for token issuance, Microsoft Entra ID calls the configured REST API during the OnTokenIssuanceStart event, just before issuing the token to the application.
    • If the REST API call fails or times out, the sign-in fails and the user/app receives a generic error; detailed error information is only visible in the sign-in logs.
    • If the REST API is never called, there will be no corresponding entries in the REST API’s own logs, but the sign-in logs still show the authentication event information for the extension when it is invoked.
    Given that the endpoint works when called directly and returns a valid onTokenIssuanceStart response, the remaining supported diagnostics and configuration checks are:
    1. Verify that the extension is actually being invoked via sign-in logs
      • Go to Microsoft Entra admin center → Entra ID → Enterprise apps → Sign-in logs.
      • Open a sign-in that should have triggered the custom extension.
      • Select the Authentication Events tab.
      • Confirm whether there is an entry for the custom authentication extension call (including HTTP status, error code, execution duration, and retry count).
      • If there is no Authentication Events entry at all for the extension, Entra ID did not attempt to call the REST API for that sign-in.
    2. Use sign-in logs + Azure Monitor for ongoing verification
      • Because the REST API call is fully controlled by Entra ID, the supported way to verify end-to-end invocation is via the Authentication Events data in sign-in logs.
      • Sign-in logs can be integrated with Azure Monitor to set alerts (for example, when the number of extension errors exceeds a threshold) and to visualize extension call volume over time.
      • This is the supported mechanism to confirm that the extension is being invoked during real user flows, beyond the REST API’s own logging.
    3. Call the REST API directly with a token issued for the extension’s app registration
      • To validate that the REST API is correctly protected and accepts tokens issued for the extension’s resource app, obtain an access token using the documented client credentials flow:
        • In Entra admin center, locate the Azure Functions authentication events API (or equivalent) app registration used as the resource for the extension.
        • Create a client secret if needed.
        • Copy the Application ID URI from Expose an API.
        • Request a token from https://login.microsoftonline.com/{tenantID}/oauth2/v2.0/token with:
          • grant_type=client_credentials
          • client_id = app’s client ID
          • client_secret = app’s secret
          • scope = {Application ID URI}/.default
        • Decode the token (for example, with https://jwt.ms) and confirm:
          • iss matches the issuer configured in the API
          • aud matches the client ID configured in the API
      • This confirms that the API protection and token validation logic match what Entra ID will use when invoking the extension.
    4. Performance and timeout considerations
      • If the REST API is invoked but does not respond within the two-second timeout, Entra ID retries and then fails the authentication if all retries time out.
      • To avoid silent failures due to timeouts:
        • Cache access tokens for downstream APIs used by the extension.
        • Add detailed logging around calls to downstream services and measure their latency.
        • Use an Azure Functions Premium or Dedicated plan (or equivalent always-warm hosting) so the API is not cold-starting during sign-in.
      • Use API testing tools and automated integration tests to validate that the extension API consistently responds within the required time window.
    5. Troubleshooting flow for a non-invoked extension
      • Confirm the extension is configured for OnTokenIssuanceStart and associated with the correct application.
      • Confirm the REST API is reachable and returns a valid response when called with a proper bearer token (already done).
      • Use sign-in logs → Authentication Events to verify whether Entra ID is attempting to call the extension at all.
      • If Authentication Events show no entry for the extension for any sign-in, the issue is in how the extension is wired into the user flow or application, not in the REST API itself.
      • If Authentication Events show entries with errors, use the HTTP status, error code, and duration from those entries to guide further debugging.
    Regarding the specific error codes (AADSTS1100001, AADSTS1003011), tenant-level toggles, or undocumented feature flags/licensing for External ID custom claims providers, there is no additional actionable information in the provided documentation beyond using sign-in logs and the above diagnostics. The documented and supported way to verify invocation is via Microsoft Entra sign-in logs → Authentication Events, combined with the REST API’s own logging and performance testing.
