need to locate my MCP certificate
Ernie Rohrbaugh 0 Reputation points
2026-05-20T16:23:52.73+00:00
I will need to download my MCP certificate so I can verify that accomplished this task.
    2026-05-20T16:24:13.5666667+00:00
    To locate and download an MCP/Microsoft Certification certificate:
    1. Go to the Microsoft Learn profile credentials page: https://learn.microsoft.com/users/me/credentials/?tab=credentials-tab.
    2. In the Credentials (or Certifications) tab, find the certification associated with the completed exam/task.
    3. Open the certification, then use the browser’s Print option and choose Save as PDF to create a downloadable copy. Certificates are no longer provided as direct file downloads; they must be viewed, printed, and saved as PDF.
    If the certification does not appear even though the exam was passed, follow the guidance in https://learn.microsoft.com/credentials/certifications/missing-certifications or contact Certification Support via https://aka.ms/CertificationSupport.
