locking issue in MSSQL
2026-05-20T07:28:48.0066667+00:00
Issue: the holdlock script has locking the multi-thread(10) insert/update
We would like to revise the multi-thread script to from (HOLDLOCK) to (UPDLOCK, SERIALIZABLE)
Original script:
MERGE testtable WITH (HOLDLOCK) AS t
USING (SELECT @P0 hjmpTS, @P1 createdTS, @P2 modifiedTS, @P3 TypePkString, @P4 OwnerPkString, @P5 PK, @P6 sealed, @P7 uniqueid, @P8 p_itemcode, @P9 p_bucketuid, @P10 aCLTS, @P11 propTS) AS s ON ( t.PK = s.PK )
WHEN MATCHED THEN UPDATE
SET hjmpTS = s.hjmpTS, createdTS = s.createdTS, modifiedTS = s.modifiedTS, TypePkString = s.TypePkString, OwnerPkString = s.OwnerPkString, PK = s.PK, sealed = s.sealed, uniqueid = s.uniqueid, p_itemcode = s.p_itemcode, p_bucketuid = s.p_bucketuid, aCLTS = s.aCLTS, propTS = s.propTS
WHEN NOT MATCHED THEN INSERT
(hjmpTS, createdTS, modifiedTS, TypePkString, OwnerPkString, PK, sealed, uniqueid, p_itemcode, p_bucketuid, aCLTS, propTS) VALUES (s.hjmpTS, s.createdTS, s.modifiedTS, s.TypePkString, s.OwnerPkString, s.PK, s.sealed, s.uniqueid, s.p_itemcode, s.p_bucketuid, s.aCLTS, s.propTS);
SQL Server Database Engine
Erland Sommarskog 137.5K Reputation points MVP Volunteer Moderator
2026-05-20T21:40:03.9333333+00:00
I did some testing, and the answer is that it does not really matter. That is, the UPDLOCK does not make any difference. MERGE takes UPDLOCK on its own initiative anyway.
As for HOLDLOCK vs. SERIALIZABLE, they are, as Marcin says, synonymous. I much prefer SERIALIZABLE since that is clearer. HOLDLOCK exists out of legacy. Then again, HOLDLOCK is easier to spell. :-)
2 additional answers
  1. Marcin Policht 109.6K Reputation points MVP Volunteer Moderator
    2026-05-20T11:14:26.68+00:00
    Try replacing HOLDLOCK with UPDLOCK, SERIALIZABLE in the MERGE statement:
    MERGE testtable WITH (UPDLOCK, SERIALIZABLE) AS t
    HOLDLOCK is equivalent to SERIALIZABLE at the table level during the transaction and might cause stronger blocking behavior in concurrent multi-threaded MERGE operations. Using UPDLOCK, SERIALIZABLE should narrow the locking intent to update locks but still protect against phantom inserts during the MERGE match evaluation.
    If the above response helps answer your question, remember to "Accept Answer" so that others in the community facing similar issues can easily find the solution. Your contribution is highly appreciated.
    hth
    Marcin
  2. Deepesh Dhake 1,245 Reputation points
    2026-05-21T04:30:05.0533333+00:00
    The real issue is usually:
    1. Merge acquires range locks
    2. serializable semantics protect against phantom inserts
    3. concurrent sessions in the same key ranges
    4. lock escalation may occur
    5. deadlocks/blocking become common
    A good approach can be:
    UPDATE testtable WITH (UPDLOCK)
    SET
        hjmpTS = @P0,
        createdTS = @P1,
        modifiedTS = @P2,
        TypePkString = @P3,
        OwnerPkString = @P4,
        sealed = @P6,
        uniqueid = @P7,
        p_itemcode = @P8,
        p_bucketuid = @P9,
        aCLTS = @P10,
        propTS = @P11
    WHERE PK = @P5;
    IF @@ROWCOUNT = 0
    BEGIN
        INSERT INTO testtable
            hjmpTS,
            createdTS,
            modifiedTS,
            TypePkString,
            OwnerPkString,
            PK,
            sealed,
            uniqueid,
            p_itemcode,
            p_bucketuid,
            aCLTS,
            propTS
        VALUES
            @P0,
            @P1,
            @P2,
            @P3,
            @P4,
            @P5,
            @P6,
            @P7,
            @P8,
            @P9,
            @P10,
            @P11
    END
    Advantages:
    1. Lower locking footprint
    2. better concurrency
    3. fewer deadlocks than merge
