Azure subscription stuck in Disabled state for 9 days despite CA$0.00 balance, all invoices Paid — Reactivate loop dead-ends, 3 support tickets unresolved
BayAnn Jlidi 5 Reputation points
2026-05-19T20:30:31.3033333+00:00
Hello — looking for help from Microsoft or the community on a reactivation issue that standard support channels have not resolved over 9 days.
Setup:
  • Subscription ID:
    2026-05-19T20:30:55.6833333+00:00
    The subscription is in the Disabled state even though the billing profile shows CA$0.00 due and all invoices are paid. In this state, self-service is limited and the normal “Reactivate → Settle past due balance” flow is failing, so the only viable path is escalation through Azure billing/support channels that can change subscription state.
    From the documented behavior:
    • A subscription can be Disabled because of past-due bills, credit expiry, spending limit, or card issues. While disabled, resources are stopped and only read/delete operations are allowed.
    • When a past-due invoice is paid, reactivation normally completes within 24 hours. If it does not, the guidance is to contact Azure Billing Support.
    • If the portal shows banners like “This subscription is disabled because payment wasn’t received. Settle outstanding charges.” but the Settle Balance / Invoices view shows CA$0.00 due, this indicates a backend billing/state inconsistency that cannot be fixed from the portal.
    Given that self-service reactivation is looping and the balance is CA$0.00, the next steps are:
    1. Open or update an Azure Billing support request (not technical-only)
      • Use the Azure portal billing support entry point, which is free:
        • Go to the support creation blade: https://portal.azure.com/#create/Microsoft.Support (also reachable via Help + support → Create a support request).
        • In the “What can we help with?” box, type Billing and select Billing.
        • Select the affected subscription from the dropdown.
        • After the initial delay when options appear, select Create a support request at the top (do not select the suggested solutions).
        • Fill in Summary/Problem type/Problem subtype (for example, “Subscription disabled / cannot reactivate after payment”), then click Next.
        • When more “solutions” appear, click Return to support request in the upper-left, then continue to Additional details and Review + create.
      • Clearly state in the ticket that:
        • The subscription is Disabled for more than 24 hours after payment.
        • Billing profile shows CA$0.00 due and all invoices are Paid.
        • The Reactivate → Settle past due balance → Invoices loop prevents self-service.
        • A previous support engineer reproduced the loop and indicated it needs escalation to the Azure billing/subscription team.
    2. Ask explicitly for escalation to the Azure billing/subscription back-end team
      • Reference the documented expectation that reactivation completes within 24 hours after payment and that this has not occurred.
      • Request that the case be escalated to the team that can:
        • Correct the subscription’s billing state, or
        • Manually change the subscription from Disabled back to Active/Enabled.
    3. If the subscription is under an Azure Plan via a partner
      • If this Azure Plan is managed through a CSP/partner, the partner can also attempt reactivation from Partner Center:
        • In Partner Center, the partner selects the Customer, then Azure subscriptions, then the relevant Azure plan.
        • On the Azure plan details page, under Azure subscription, select the Inactive tab.
        • Select the affected subscription and choose Reactivate subscription.
      • The partner must have Global admin and Admin agent roles, and the Azure plan itself must be active. If the partner cannot reactivate, they must open a Partner Center support case and request escalation using the same details (Disabled state, CA$0.00 due, paid invoice, reactivation loop).
    4. If using Partner APIs (for partners only)
      • A CSP partner with a partner application can call the documented Reactivate an Azure subscription REST API:
        • POST /v1/customers/{customer_id}/subscriptions/{subscription_id}/azureEntitlements/{entitlement_id}/reactivate
      • If this returns an error (for example, 900337 or 900335), that error and correlation ID should be included in the Partner Center support escalation so Microsoft can correct the entitlement state.
    5. If payment is confirmed but subscription remains disabled
      • The FAQ for past-due balances states that if payment is processed but the subscription is still disabled, the next step is to contact Azure support. This matches the current situation and reinforces that only support can fix the state.
    There is no documented self-service method to repair a subscription that is stuck in Disabled with CA$0.00 due and a completed payment beyond the 24‑hour window. Resolution requires Azure Billing/Commerce or Partner Center support to correct the backend subscription/entitlement state or manually reactivate the subscription.
